kevjns Posted August 16, 2007 Share Posted August 16, 2007 not sure if this has been posted before and lost when everything went down but hope it come in handy for people INXX BONNET LIFTER INSTALLATION ESCORT MK6 ADDING GAS LIFT STRUTS TO THE BONNET This job is very easy and anyone can do it, makes the engine bay a lot nicer place to work. The bonnet lifters will be near impossible to compress by hand, so don't think they are faulty when you receive them. Once they are installed on the car, the bonnet should lift itself up. RequirementsINXX Bonnet Lifters Kit for Escort MK62x Extra Washers10mm Spanner10mm SocketCentre PunchDrillClamp The first thing you need to is to mark out the first hole of the bracketTo do this you need to locate the rectangle cut out in you wing then working towards the windscreen the centre of the ball that the lifter goes on has to 45 mm from the edge. Then use a clamp to hold the bracket in place, (the tape was used to take the photo). Next Punch a hole in the centre of the holes to make drilling easier. Then remove the bracket and using a suitable sized drill, drill the holes. Next you want to place the Bracket under the lip of the wing and place the bolts through the top and secure the nuts underneath. Next You will need to get the remaining lifter mounting bolt the supplied washer and the extra washer, then placing them through the lowest hole in the bonnet bracket with a washer each side. You are now ready to fit the lifters, in the caps at each end is a pin that needs removing and keeping safe you will need to replace it once the lifters are on the mountings. Repeat the process on the otherside Picture to show how the fixing should look. Close up of fitted fixing bracket. You can see the pin in the picture that you have to remove to fit the lifter to the mount. Link to comment Share on other sites More sharing options...
Tez162003 Posted August 16, 2007 Share Posted August 16, 2007 it has been posted before a couple of months ago so should be here somewhere! but thanks all the same, i have them but didnt like the INXX Logos. TIP.... if you dont like the INXX logo's on these use megs metal polish and it takes it straight off! Link to comment Share on other sites More sharing options...
kevjns Posted August 16, 2007 Author Share Posted August 16, 2007 it has been posted before a couple of months ago so should be here somewhere! but thanks all the same, i have them but didnt like the INXX Logos. TIP.... if you dont like the INXX logo's on these use megs metal polish and it takes it straight off! nice one was wondering how to get it of why they made the logo so big i dont know Link to comment Share on other sites More sharing options...
