Anyone fitted one and seen any benefits?
Ryan
Well, probably not going to help you, but on my Orion, i've had adjustable pedals, so the bias can be adjusted between the front/rear, but i've also got 2 master cylinders and no servo, not a clue what it drives like though.
The biggest worry would be if you set the bias up wrong, your gonna be going backwards alot (or not alot if you hit something lol)
I know exactly what your saying. I understand the principles of how it works.
Just thought it could work once my bigger brakes are fitted to the front?
Im not all too sure whether you'd get much of an advantage on the road, the only reason I have gone that route is that I didnt have anywhere to easily fit the Cosworth ABS/Master Cylinder/Servo etc.
