Posted December 5, 200717 yr just painted and fitted the new Morettes and at first thought they were the wrong ones, http://i3.tinypic.com/71r00eo.jpg http://i3.tinypic.com/82w6jit.jpg then i did a bit of browsing found that there are 2 headlight and sidelight sizes this is mine .... (Wider headlight, small sidelight) http://i19.tinypic.com/6p8s491.jpg This is the other size , and it's also the size of sidelight i need to replace my existing one http://i11.tinypic.com/85431pu.jpg So can anyone enlighten me as to the models? 5a?........5b? need to know so i can order the correct sidelight
December 5, 200717 yr you have standard mk5 morettes, the longer ones are xr/rs morettes. so a standard mk5 sidelight will be needed Edited December 5, 200717 yr by reid
December 5, 200717 yr you have standard mk5 morettes, the longer ones are xr/rs morettes. so a standard mk5 sidelight will be needed indicators shame theyre not rs/xr ones
December 5, 200717 yr Author this shows the difference with morettes fitted This is obviously the correct set for my model http://i19.tinypic.com/6y50zcz.jpg But this is the set i have, so hence needing the co-responding sidelight http://i12.tinypic.com/6s7179h.jpg you have standard mk5 morettes, the longer ones are xr/rs morettes. so a standard mk5 sidelight will be needed cheers for that........now i know what i'm looking for tomorrow
December 6, 200717 yr Looks great, leave the fogs out if your getting lamps Or i could just see if i have my old ones as i replaced mine with the smaller sidelights you already have.
December 6, 200717 yr Author Looks great, leave the fogs out if your getting lamps Or i could just see if i have my old ones as i replaced mine with the smaller sidelights you already have. can you give me a bell on 556648 ASAP
December 6, 200717 yr please sell the morrettes you have and either get cossie ones, or refit your xr/cossie standard headlights
December 6, 200717 yr Looks great, leave the fogs out if your getting lamps Or i could just see if i have my old ones as i replaced mine with the smaller sidelights you already have. can you give me a bell on 556648 ASAP cant do much atm brute due to work but im 99% sure i have them in the shed mate, ill see if i can sort em out for you.
December 6, 200717 yr Author Right found em now, i can drop em off later bout 8ish if you want collin?good man that'd be great Edited December 6, 200717 yr by Brute
