whenever i check out the reports section, specifically the evo pod pictures thread the screen goes crazy and it wont draw any of the frames its pretty weird actually, ive never seen anything like it
i thought id been hacked or something its proberbly just turbosport being gay...
a number of things can cause your screen to go like that...but by the looks of things on the picture, its freezing/jamming which normally means:
Your RAM (ure on XP so its supposed to recycle itself) OR Your GFX card.....Ask anyone else see if they have a simular problem, if they are then it could be something on the site triggering it, if not it could be an internal problem on your end
normally once that happens its an indication that you need to reboot as your computer can't handle the physicial load your trying to put on it......a good reboot is always in favour to reset your ram chips.....if and then it dont work, you could try this, delete all temporarily internet files make sure your cache is all empty, reboot again and see.....if not, then i can't really see anything in that thread that a gfx wouldn't like.....maybe the lots of un-reachable pictures thats trying to load is causing something to jam within your system.
try another thread that has lots of pics uploaded via turbosport, and if it crashes...
Just my opinion on things, could be wrong....but when am i wrong? :D
what cpu speed, ram and size of gfx card you got?
Edited by Pelles
AMD athlon 2100 cpu
512mb 400mhz pc3200 DDR Ram
GF4 ti 4600 128mb
Asus Nforce2 motherboard
its just that thread, and still does it now, and my temp internet files was one of the first things i tried, its fooking weird.... :suprise:
what about the temperture of your pc?
sounds like an old problem i was having, once i tried to load any big applications like a game once my pc was "hot" it would crash out on me.....a more uprated fan does the job, only cost a tener....once it does crash out on you, reset it, and see what the temperture is (normally tells you at start up, or go into BIOS and check it in the PC Health section) and post the temperture on here.
Lol im running a copper heatsink Orb fan my cpu is at 30.C and my mobo at 20.C
i also have 2 case fans at the front of my tower, and two at the back, and one on the side
its like an icebox in there mate im sure it aint hardware..
gonna delete all temp internet crap by hand and set the buffer higher or lower...
Ive also got a retail version of windows Xp home with all the updates and service packs
