JadeFalcon Posted July 30, 2008 Share Posted July 30, 2008 noticed the nearside cv boot on my (M) plate escort 1.6 lx has either split or gone bad chucking out all the grease, have a mechanic coming to help me with that on friday, but i noticed something odd when its up on axel stands. its jacked up both sides so front drive wheels are off the floor so i could rotate wheels to check for cv joint failure, when i turn steering from left to right and vise-versa there is a clicking sound coming from somewhere that i cannot determine, have checked bearings they seem fine no play, also no odd sounds apart from brake pad rubbing when turn the wheels by hand, so i dont really know what could be wrong would be helpful if anybody here could give me some pointers as to what it could be or what other checks i should, as i'm a noob when it comes to mechanics, i can read a haynes but i'm no trained mechanic much thanks in advance Link to comment Share on other sites More sharing options...
SteveB Posted July 31, 2008 Share Posted July 31, 2008 noticed the nearside cv boot on my (M) plate escort 1.6 lx has either split or gone bad chucking out all the grease, have a mechanic coming to help me with that on friday, but i noticed something odd when its up on axel stands. its jacked up both sides so front drive wheels are off the floor so i could rotate wheels to check for cv joint failure, when i turn steering from left to right and vise-versa there is a clicking sound coming from somewhere that i cannot determine, have checked bearings they seem fine no play, also no odd sounds apart from brake pad rubbing when turn the wheels by hand, so i dont really know what could be wrong would be helpful if anybody here could give me some pointers as to what it could be or what other checks i should, as i'm a noob when it comes to mechanics, i can read a haynes but i'm no trained mechanic much thanks in advance Check for a broken road spring. Link to comment Share on other sites More sharing options...
trev27 Posted July 31, 2008 Share Posted July 31, 2008 are the cv joints ok? Link to comment Share on other sites More sharing options...
JadeFalcon Posted July 31, 2008 Author Share Posted July 31, 2008 i span the wheels n they sound fine, bearings seem good aswell, i think i managed to notice the boot going quite quick as i never noticed the grease about 2 weeks ago steve, what do you mean exactly by road spring ? as in suspension strut spring ? i'm a mechanical noob Link to comment Share on other sites More sharing options...
Danny1107 Posted July 31, 2008 Share Posted July 31, 2008 i span the wheels n they sound fine, bearings seem good aswell, i think i managed to notice the boot going quite quick as i never noticed the grease about 2 weeks ago steve, what do you mean exactly by road spring ? as in suspension strut spring ? i'm a mechanical noob spot on, check that its not broken, they usualy go nere the top or nere the bottom I've noticed Link to comment Share on other sites More sharing options...
JadeFalcon Posted July 31, 2008 Author Share Posted July 31, 2008 checked them they seem to be ok.. but i definetly think its something to do with the suspension as its clicking when i turn wheels (on stands), doesnt do it when car on the ground, do the springs usually rotate when turning the wheels ? springs are solid and in place tried pulling them in diff directions so they not loose or anything i wd40'd the springs but that has not solved it Link to comment Share on other sites More sharing options...
SteveB Posted August 1, 2008 Share Posted August 1, 2008 checked them they seem to be ok.. but i definetly think its something to do with the suspension as its clicking when i turn wheels (on stands), doesnt do it when car on the ground, do the springs usually rotate when turning the wheels ? springs are solid and in place tried pulling them in diff directions so they not loose or anything i wd40'd the springs but that has not solved it If a spring breaks it usually breaks near to the end, and the spring still feels tight(ish). All I can suggest is that you get someone to move the steering wheel left and right while you stick your head under the arch and listen where the noise is coming from. Link to comment Share on other sites More sharing options...
JadeFalcon Posted August 3, 2008 Author Share Posted August 3, 2008 mechanic had a look said it usually happens when weight is not on the springs, nothing to worry about, he also did the cv boot joint for me thanks for all the advice Link to comment Share on other sites More sharing options...
