marty812 Posted December 17, 2008 Share Posted December 17, 2008 Hi all new to this and have the common problem of heater blower not working so i was hoping we could start a checking procedure to narrow down the problem for example checking the switch and the motor and fusebox and so on.i am not a mechanic so i think it would be helpfull for people to be able to sort this out so lets have a starting list and how to check from all you guys who know what they are doing thanks Link to comment Share on other sites More sharing options...
robexor Posted December 17, 2008 Share Posted December 17, 2008 Is your problem, that the blowers are not working or you have not heat. I have the same problem but if i give the blower motor a 12V feed from a car battery charger they spin up fine, ptu back in the car they dont work at all and i have around 11.4 to 11.8v doing to the blower motor when in the car. ie there is power from in the multi plug that goes on top of the blowers. If your blowers are not working then it could be 1. The actual speed switch on the dash [1,2,3] is faulty2. The blower motor them selfs have packup3. The fuse box is knackered.4. The resistor on the blower motas is knacker.5. You have a bad earth that connects to the blower motors6. Check the fuse for the heater blowers. Its a pig to get to the actual blowers them self, u need to take the battery out, undo about 6 bolts/screws that hold the bulkhead to the car, cut the cable ties that are holding the main power cables that run along the back, take off both wiper arms, take of the scuttle panel, then pull the bulkhead toward the engine. [its made of plastic] then remove the large plastic cover that covers the blowers. Some pics for u. http://i200.photobucket.com/albums/aa17/robexor/Escort/DSC00250.jpg Plastic cover that covers the blower motor. http://i200.photobucket.com/albums/aa17/robexor/Escort/DSC00252.jpg Blower Motor http://i200.photobucket.com/albums/aa17/robexor/Escort/DSC00253.jpg Blower Motor Conectors http://i200.photobucket.com/albums/aa17/robexor/Escort/DSC00255.jpg Link to comment Share on other sites More sharing options...
marty812 Posted December 17, 2008 Author Share Posted December 17, 2008 yes my blowers are not coming on at the switch i have that goes into fuse box and blower works thats what i am doing at the moment have removed fuse box but could not see anything obvious so thats where i am at the moment guessing fuse box but just thought as its a common problem we could start a list of things to check and how to check Link to comment Share on other sites More sharing options...
robexor Posted December 17, 2008 Share Posted December 17, 2008 cool so if you put a 12V feed direct on to the 3 metal pins ontop of the blower motor, do they spin, if not its buggered, no need to remove fusebox Link to comment Share on other sites More sharing options...
marty812 Posted December 17, 2008 Author Share Posted December 17, 2008 sorry my last reply was missing some infohave checked blower motor with live feed all 3 speeds workalso have hot wired at plug that is on fuse box and blower works on all time at moment on a low speedchanged switch on dashboard Link to comment Share on other sites More sharing options...
robexor Posted December 17, 2008 Share Posted December 17, 2008 hmm sounds like the same problem as me, basically if you use the internal car wiring , the motors dont work.. This must be sumin so silly that we are both missing. Link to comment Share on other sites More sharing options...
marty812 Posted December 17, 2008 Author Share Posted December 17, 2008 looks that way thats why im thinking fuse box as everyone seams to point to Link to comment Share on other sites More sharing options...
robexor Posted December 17, 2008 Share Posted December 17, 2008 k Mate keep in contact with me about this i got another blower mota and resistor coming tomorrow ill let u know if it fixes it, if not then u try with fuse box ect Link to comment Share on other sites More sharing options...
jj08 Posted December 17, 2008 Share Posted December 17, 2008 think you will find that the track feeding the bottom of the fuse for the blowers within the fusebox have become open circuit,the whole fusebox is a tripple sandwich that has crap soldering on the sides,I`ve taken apart loads and fixed them,very involved,a quick fix is to put a link wire from another fuse bottom across to the bottom of the blower fuse,all you do is wedge a bit of wire in the slot on both fuses if you follow me.Its a temporary fix tho`just to get you going.The blowers are usually the first to give up then you will find the interior lights next,then anything might just go.Permanant fix~another fusebox I`m afraid. Link to comment Share on other sites More sharing options...
robexor Posted December 18, 2008 Share Posted December 18, 2008 Ok but if i find another fusebox it will be 12 years old, same as mine lol how do i know that wont pack up lol Can you do/get re-con fusebox's ? Link to comment Share on other sites More sharing options...
marty812 Posted December 18, 2008 Author Share Posted December 18, 2008 i think he may be right i will test theory today with wire but new box about 500 so have to take risk with old box Link to comment Share on other sites More sharing options...
marty812 Posted December 18, 2008 Author Share Posted December 18, 2008 ok tried tracking the bottom of fuse with another no joy but i hav joined 2 wires from multiplug and fan comes on only 1 speed but works sp where to now Link to comment Share on other sites More sharing options...
robexor Posted December 18, 2008 Share Posted December 18, 2008 Marty u got any pics of what i did please, my fans have not turned up yet so ant test it Link to comment Share on other sites More sharing options...
marty812 Posted December 18, 2008 Author Share Posted December 18, 2008 no sorry no pics but if get time tomorrow will take cover off again an let you know what colour wires i joined together Link to comment Share on other sites More sharing options...
marty812 Posted December 19, 2008 Author Share Posted December 19, 2008 ok my son took cover off today and looked at joined wires on multiplug the first wire is purple/black on first row i thinksecond wire is puple/blue on second row i think cant be 100% sure of rows as box all back in place just a thought light on switch for ac does not come on and am only getting about 8 volts at switch as joining fuses together does not work could it be something else any ideas Link to comment Share on other sites More sharing options...
