andy_b123 Posted March 18, 2009 Share Posted March 18, 2009 hi i have a 1600 zetec escort which failed MOT on emissions abmissmallyI have since replaced cat/lambda better but not perfect so chose to replace afm.... Engine now wont rev past 4k on full throttle although will rev fine if the throttle is feathered and revs brought up slowly, first thought was faulty new afm so i took it back yesterday and recieved another this morning still the same, oh both AFM are NEW ones! Car runs fine on base map (afm unplugged) revs perfectly Have tested TPS readout is perfect Does any one have values for afm whilst running so i can check them at ecu end to make sure its not a wiring fault any ideas.......need to retest it tomorrow ideally.....help is much appreciated Andy Link to comment Share on other sites More sharing options...
