stiffy999 Posted March 22, 2009 Share Posted March 22, 2009 changed my k and n air filter today but there was nowhere to put the oil breather pipe so i just stuck it to the brake master cylinder gave her a little tickle to see if the much larger air filter had changed ote got to 4k in 2nd ..... bang lost 90% of power and it sounded like a tractor managed to limp home and have a look and the engine is making a seriosly loud noise mainly from the top end (cams) what could this be ? Link to comment Share on other sites More sharing options...
escort4x4 Posted March 22, 2009 Share Posted March 22, 2009 could be a vacuum hose mate, if you have popped one then this can happeni doubt you would have blown something at 4k in 2nd gear Link to comment Share on other sites More sharing options...
stiffy999 Posted March 22, 2009 Author Share Posted March 22, 2009 wtf is that lmao is it fixable :S the nocking soung is from the engine tho it does not sound good do you think this is because i didnt connect my breather pipe ? Link to comment Share on other sites More sharing options...
escort4x4 Posted March 22, 2009 Share Posted March 22, 2009 if its a vacuum pipe then yes, its fixable, everything is fixable. where does the knocking come fromi doubt it could be due to the breather pipe. but id put everything standard back on n go from there Link to comment Share on other sites More sharing options...
stiffy999 Posted March 22, 2009 Author Share Posted March 22, 2009 rite in the middle of the head the thing is my icv is screwed it used to stick at 3k for 2- 8 seconds depending on how bad it felt but if i disconnected battery n left it for 15 minutes it fixed that could it be something to do with that ? Link to comment Share on other sites More sharing options...
