onehotminute_191 Posted April 12, 2009 Share Posted April 12, 2009 cant notice any problems at idle or high engine speed. only when at low revs and high gear. eg 30oddMPH in 4th or 5th. its fine when cruising at that speed but when i acclerate it judders. i think it could be plugs, leads or coil pack. ive just had a look and all leads are recieving a spark but this is only at idle speed.so if i assume that the coil pack and lead are fine then 1 or more spark plug is knackered. even though it runs ok maybe it can spark well enough for ignition? any ideas on that or anything else i should look out for? cheers Link to comment Share on other sites More sharing options...
onehotminute_191 Posted April 12, 2009 Author Share Posted April 12, 2009 ive just tested the coil pack ive got 1 coil at 14.54ohm and the other 2 at 16.50ohms across each of the pairs of coils. (its a v6). so to me that seems within reason unless im wrong??? not sure. i dont think thats the problem other wise i would be getting 2 cylinders working but its doesnt fell bad enough to be that. i tried testing resistance betwwen the terminals and HT lead ends but i was getting open circuit on all terminals. im not sure of the internals of a coil pack so not sure if thats correct but maybe the resistance was too high for the meter. anyone know what results i should be getting for that? Link to comment Share on other sites More sharing options...
bloke Posted April 12, 2009 Share Posted April 12, 2009 (edited) ive just tested the coil pack ive got 1 coil at 14.54ohm and the other 2 at 16.50ohms across each of the pairs of coils. (its a v6). so to me that seems within reason unless im wrong??? not sure. i dont think thats the problem other wise i would be getting 2 cylinders working but its doesnt fell bad enough to be that. i tried testing resistance betwwen the terminals and HT lead ends but i was getting open circuit on all terminals. im not sure of the internals of a coil pack so not sure if thats correct but maybe the resistance was too high for the meter. anyone know what results i should be getting for that? If it went open circuit on even one of the packs it would missfire like a pig which v6 is it? Edited April 12, 2009 by bloke Link to comment Share on other sites More sharing options...
Scott_GT Posted April 12, 2009 Share Posted April 12, 2009 i had the same symtons on my escort, changed coil pack made it a bit better but changed the plugs as it was as smooth as shaft Link to comment Share on other sites More sharing options...
onehotminute_191 Posted April 13, 2009 Author Share Posted April 13, 2009 its a mondeo st24. im going to change the leads and plugs as part of the service. i just thought that the coil pack shouldnt be showing open circuit but im getting it everywhere from the plug pins to the leads. Link to comment Share on other sites More sharing options...
adamGTI Posted April 13, 2009 Share Posted April 13, 2009 ive had loads of problems with the v6 mondeo cracking the ceramic on the plugs. just take them out and have a loook Link to comment Share on other sites More sharing options...
