Hand Brake Warning Light
scrapheap
I have just checked the brake fluid level and it was on the minimum, so I think that might have caused it. Or at least it fits in with the symptoms. I have topped it up to Max now and hopefull that will solve the problem. If it doesn't then it is time to check the rest of the brake components. Oh and I tested the brakes afterwards, just to make sure that it still stops after fiddling with the brake fluid, otherwise it might have been 8o at the first junction I came to.
