Mr. Nick Posted February 13, 2010 Share Posted February 13, 2010 Right, i'm replacing my clutch today if all goes well.. what i need to know is.. do i have to drop the engine out or remove the bell housing?do we have some sort of guide for it? there will be enough people around for help and advice, but i want to know for things to look out for and general directions to help speed up the process! swiftly replied help would be very appreciated!! Link to comment Share on other sites More sharing options...
scottg17 Posted February 13, 2010 Share Posted February 13, 2010 okay, 'jack up the front wheels and remove the pass side wheel.. put on stands tho! next split the balljoint on the wishbone and track rod end.Remove the pass drive shaft (i just split at the inner joint to prevent oil leakage.remove the speedo cable, gear Linkage and support running back under the car.disconnect the clutch cable.unbolt the starter and tie out the wayjack under the box, Remove the front and rear mounts.undo all the bell housing bolts, Drop the jack and remove the box. i think that about it Link to comment Share on other sites More sharing options...
Mr. Nick Posted February 13, 2010 Author Share Posted February 13, 2010 Thanks mate, not far off now! anything else?? Link to comment Share on other sites More sharing options...
Mr. Nick Posted February 14, 2010 Author Share Posted February 14, 2010 right we finally got the clutch off today and the new one in. problem we're having is the fact we can get the front of the gearbox/bell housing lined up, but not the back. it is doing my head in as i'd like to get it sorted today!! Link to comment Share on other sites More sharing options...
fizzwhizz Posted February 14, 2010 Share Posted February 14, 2010 im lost.. What u mean you cant get the back of the G/box lined up ??? Once the inner spline is within the engine block , jsut simple turn it clock wise & anti clock wise within an inch or 2 movement which then should allow the gearbox to slot in place.. Wotever u do dont try and force the gearbox on by tightening it with the bolts as you will pull the threads out of the G,box as they are rubbish for keeping threads. Link to comment Share on other sites More sharing options...
scottg17 Posted February 14, 2010 Share Posted February 14, 2010 clutch is probably not aligned right clutch is probably not aligned right Link to comment Share on other sites More sharing options...
Mr. Nick Posted February 14, 2010 Author Share Posted February 14, 2010 Sorted! 2 days! 1 day to get it off, 1 day to fit it! The air con is such a B!tch though! atleast its done! I do NOT intend to ever do that again! Had to learn though i guess.. Haha, its wierd, my biting point was SO far out normally, now its scary how far down it is! it engages about half a cm off the floor! :/ but woop, its done :D Link to comment Share on other sites More sharing options...
fizzwhizz Posted February 14, 2010 Share Posted February 14, 2010 did u take the arm off the G/box by anychance? By the arm i mean the part that the cable conects to.. I assume u also changed your clutch release bearing whilst the box was off ? Link to comment Share on other sites More sharing options...
scottg17 Posted February 15, 2010 Share Posted February 15, 2010 Sorted! 2 days! 1 day to get it off, 1 day to fit it! The air con is such a B!tch though! atleast its done! I do NOT intend to ever do that again! Had to learn though i guess.. it engages about half a cm off the floor! :/ but woop, its done :D Neither did i BUT.. my gearbox is now lying in my garden just now but i beat you... It only took me 2.5 hours to get it out Link to comment Share on other sites More sharing options...
mr matty Posted February 15, 2010 Share Posted February 15, 2010 Sorted! 2 days! 1 day to get it off, 1 day to fit it! The air con is such a B!tch though! atleast its done! I do NOT intend to ever do that again! Had to learn though i guess.. it engages about half a cm off the floor! :/ but woop, its done :D Neither did i BUT.. my gearbox is now lying in my garden just now but i beat you... It only took me 2.5 hours to get it out i got mine in and out all dun in about that time !! Link to comment Share on other sites More sharing options...
scottg17 Posted February 16, 2010 Share Posted February 16, 2010 Sorted! 2 days! 1 day to get it off, 1 day to fit it! The air con is such a B!tch though! atleast its done! I do NOT intend to ever do that again! Had to learn though i guess.. it engages about half a cm off the floor! :/ but woop, its done :D Neither did i BUT.. my gearbox is now lying in my garden just now but i beat you... It only took me 2.5 hours to get it out i got mine in and out all dun in about that time !! I was going slow,,, and it was freezing Link to comment Share on other sites More sharing options...
