davies1644 Posted August 16, 2010 Share Posted August 16, 2010 i have recently done an axle over leaf conversion and have found the exhaust hits the axle so i have removed this so i can put it under the axle the problem i have though is the shocks are maxxed out so theyre fully compressed when i go over bumps and its causing the van to have no suspension so can you get a shorter shock?? or anything?? anyone had this problem?? Link to comment Share on other sites More sharing options...
POSTIE Posted August 16, 2010 Share Posted August 16, 2010 YEA HAVEING THE PROBLEM MY SELF U CAN LENGTHEN THE MOUNTS ON THE AXEL BUT AS FOR SHORTER SHOCKS I HAVENT FOUND ANY YET HOPE THAT HELPS A LITTLE Link to comment Share on other sites More sharing options...
davies1644 Posted August 16, 2010 Author Share Posted August 16, 2010 yeah i have done the same havent mounted them yet tho only thing is i dont know if it would pass an mot like that as it has a piece of metal to move the mount down Link to comment Share on other sites More sharing options...
tezmanian devil Posted August 20, 2010 Share Posted August 20, 2010 Im having some longer shackles made if you want a pair?They'll raise the rear by 1" so the back will sit level with the front, and gives you abit of travel on the suspension befour you hit the stops... Link to comment Share on other sites More sharing options...
