POWERSCORT Posted August 20, 2003 Share Posted August 20, 2003 can anybody tell me if it is worth getting a power boost valve for my i.8 si, will i notice a lot of difference from it? is it easy to fit,or should i get somebody with a bit more knowhow to do it as im not the most patient of people. and would i have to have the engine tuned once fitted or not? thanks lads Link to comment Share on other sites More sharing options...
RSPOOJ Posted August 20, 2003 Share Posted August 20, 2003 i fitted one to my 1.6i..and def noticed the difference..but not till it was setup properly..ideally on a rolling road...there dead easy to fit..all you need comes with..and the instructions are fairly stright forward...took me about 20mins tops...FSE say they come preset at standard pressure for your vehicle..but thats utter b*lloX matey..will need setting up...if you tinker too much or wind it right up you'll nacker the fuel pump...i went thru 2 before i had it dealt with Link to comment Share on other sites More sharing options...
POWERSCORT Posted August 21, 2003 Author Share Posted August 21, 2003 thanks for that m8 Link to comment Share on other sites More sharing options...
Rich Posted August 21, 2003 Share Posted August 21, 2003 go on then some explain to me what they are, sumthing to do with excess fuel collection or something i was told Link to comment Share on other sites More sharing options...
muzzy Posted August 21, 2003 Share Posted August 21, 2003 Its a little valve that boosts the pressure Ive been it just add more presure in ur fuel line Link to comment Share on other sites More sharing options...
