268 Posted September 19, 2012 Share Posted September 19, 2012 Hi As some of you may have seen I recenly changed my clutch... I've done a 1000 miles on it and it's been running great. In the last 2 days I've been findin that occasionaly it's been popping out of 3rd gear into neutral. The gearbox oil is just under the max line so not compleely full? could this be the problem or is it another major fault that's only gonna get worse? Cheers Link to comment Share on other sites More sharing options...
ekkie7 Posted September 19, 2012 Share Posted September 19, 2012 Hi As some of you may have seen I recenly changed my clutch... I've done a 1000 miles on it and it's been running great. In the last 2 days I've been findin that occasionaly it's been popping out of 3rd gear into neutral. The gearbox oil is just under the max line so not compleely full? could this be the problem or is it another major fault that's only gonna get worse? CheersCheck your haynes blood!! only messing lol,sounds like the selector is fooked or even you havent aligned the gearing properly with the selector,normaly reverse is a pratt to get in if its that Link to comment Share on other sites More sharing options...
