cherrybeard Posted March 22, 2013 Share Posted March 22, 2013 When you crank, are you getting 12v at the starter? When you crank, are you getting 12v at the starter?Obviously, if you are getting 12v but no cranking, then its the starter itself.If you are getting less than 12v then it is a degradation of wiring or relays.No voltage points to break in wiring, knackered relay or immobiliser.Also check the main feed and earth to and from the starter. Link to comment Share on other sites More sharing options...
