mikes-fat-arsed-estate Posted August 14, 2013 Share Posted August 14, 2013 hi im after a maf for a td or tdi not sure if there would be a difference between the 2?im not 100% sure i need one but i personally feel its don on mpg but i have not done a brim test to confirm yet, also if i floor it the power is delivered in waves but on the flat spot if i ease of the pedal it picks up again nicely would a bad maf cause this symptoms?thanks Link to comment Share on other sites More sharing options...
VanMan_Jas Posted November 4, 2013 Share Posted November 4, 2013 hi im after a maf for a td or tdi not sure if there would be a difference between the 2?im not 100% sure i need one but i personally feel its don on mpg but i have not done a brim test to confirm yet, also if i floor it the power is delivered in waves but on the flat spot if i ease of the pedal it picks up again nicely would a bad maf cause this symptoms?thanksLittle late here... do you still need one? I might have one in my garage... I'll check the part number and confirm its the right one. Jas Link to comment Share on other sites More sharing options...
