Chris_1.8Si Posted September 15, 2003 Share Posted September 15, 2003 I dunno what speed i should expect this engine to idle at since 1. its done 133k and 2 i'm never owned a 1.8 si before!! any help??? Link to comment Share on other sites More sharing options...
John Posted September 15, 2003 Share Posted September 15, 2003 at idle once it all warmed up it should sit somewhere between 750 - 900 rpm i believe. it's somewhere around that anyway Link to comment Share on other sites More sharing options...
white_van_matt Posted September 16, 2003 Share Posted September 16, 2003 Just a thought coz someone else didn't know it on another forum - it's got injection and therefore an auto choke so it should idle a bit higher on a cold day than on a warm one Sorry if i insulted your intelligence there Link to comment Share on other sites More sharing options...
John Posted September 16, 2003 Share Posted September 16, 2003 also they have way overly complicated engine management systems so knock sensors etc will alter timing, engine speed etc etc, but it shouldn't alter the engine speed to such a level that it's really noticable i'm only takling about it going up or down by say 50rpm max. Link to comment Share on other sites More sharing options...
Mk6 Si Ross Posted September 16, 2003 Share Posted September 16, 2003 mine idles at about 400 rpm!!! Link to comment Share on other sites More sharing options...
Chris_1.8Si Posted September 16, 2003 Author Share Posted September 16, 2003 i only ask cos my clio used to idle at about 500rpm... this engine seems to float around the 1000rpm mark...when its had a run of say my 20 miles home from work, i can let it sit and it'll drop to about 750/800rpm then rise back up to about 1000, then after about 10 15 seconds it'll drop down to 750/800 again and then back to 1000, it carries on doing this all by itself...The thing that worries me is that the lowest it seems to idle is 750rpm for that brief time it drops to it and then rises back up! and it doesn't help when people like Ross say that there engine idles at 500 rpm! Link to comment Share on other sites More sharing options...
marcus Posted September 16, 2003 Share Posted September 16, 2003 (edited) mine usually idels at 750 but recently i have had the same problem as you when it idles irratically. anybody know how to sort it??? Marcus Edited September 16, 2003 by marcus Link to comment Share on other sites More sharing options...
simonh1 Posted September 16, 2003 Share Posted September 16, 2003 Idle control valve ?????? Link to comment Share on other sites More sharing options...
