John16v Posted September 15, 2003 Share Posted September 15, 2003 Roughly how much would a 1.8 cost? and whats the difference as i heard that some have 115bhp and some have 130bhp? just thinking bout it for next year maybe? john Link to comment Share on other sites More sharing options...
Mk6 Si Ross Posted September 16, 2003 Share Posted September 16, 2003 there's 3 engine varients!!!! 105, 115 and the convertible's engine the 130bhp, think the difference was cams and ecu or something like that. Link to comment Share on other sites More sharing options...
simonh1 Posted September 16, 2003 Share Posted September 16, 2003 The 130 has different cam profiles, bigger throttle body, 33% bigger valves and a different map in the ECU.......... Link to comment Share on other sites More sharing options...
Mk6 Si Ross Posted September 16, 2003 Share Posted September 16, 2003 Si, does the 1.8 head fit straight onto the 2.0 block???? I'm hoping so for the future as my heads already been done Link to comment Share on other sites More sharing options...
simonh1 Posted September 16, 2003 Share Posted September 16, 2003 Yes mate, they are basically the same as far as I'm aware, as the 1.8 130 head has the same spec ie. valve sizes as the 2.0. Link to comment Share on other sites More sharing options...
Mk6 Si Ross Posted September 16, 2003 Share Posted September 16, 2003 that was/is the worry, bore size etc Link to comment Share on other sites More sharing options...
John16v Posted September 17, 2003 Author Share Posted September 17, 2003 Si, so roughly how much would a 130 bhp engine cost and where could i possibly pick one up?? john Link to comment Share on other sites More sharing options...
simonh1 Posted September 17, 2003 Share Posted September 17, 2003 Err, try the scrappy mate, lots of written off Mk5 130 XR3i's in there, Oh and I've got one in me garage............just needs a set of cams........ Link to comment Share on other sites More sharing options...
John16v Posted September 17, 2003 Author Share Posted September 17, 2003 so could put new performance cams in it then? or would it need the standard ones? john Link to comment Share on other sites More sharing options...
simonh1 Posted September 18, 2003 Share Posted September 18, 2003 Best to use a set of aftermarket jobbies, it would also need a top end gasket set, head bolts, cam belt, sump gasket and a few bits from your engine, namely, water pump, sump and maybe a couple of brackets. Link to comment Share on other sites More sharing options...
