mdtb Posted November 11, 2003 Share Posted November 11, 2003 hi all i drive an escort mk 6 ghia x 1.8i n am havin problem wi engine, gauge showin its red hot all time but it isnt i have replaced thermostat and temperature sender unit to no avail does n e 1 else have same problem Link to comment Share on other sites More sharing options...
Mk6 Si Ross Posted November 11, 2003 Share Posted November 11, 2003 does the fan definately work???? Fan switch maybe??? Link to comment Share on other sites More sharing options...
mdtb Posted November 11, 2003 Author Share Posted November 11, 2003 the fans blowin all time and doesnt effect temp showin on gauge Link to comment Share on other sites More sharing options...
900ss Posted November 11, 2003 Share Posted November 11, 2003 Does the gauge go straight over to hot when you turn the ignition on? If it does the sender is duff or wrong or you have a short in the loom or the sender plug has corrosion in it or maybe the gauge itself is duff.If it just gets hot very quickly and you know the fans are cutting in ok and the thermostat isn’t faulty then it may have a blown head gasket or a cracked head or it maybe just a blocked rad. Link to comment Share on other sites More sharing options...
mdtb Posted November 12, 2003 Author Share Posted November 12, 2003 i ve been told my head gasket is ok the bloke at garage cant understand whats wrong my mate drives a 1.8Si an he has exactly same problem hes a mechanic like n he dont know what it is Link to comment Share on other sites More sharing options...
