toonarmy Posted January 14, 2004 Share Posted January 14, 2004 whats the power of the ice in your car. mine is 2x 800watt rockford fosgate subs. 1x 700watt rockford fosgate mono amp.alpine head unit 4x 65 watt pre outs 300 watt 6x9. still to do..4 channel amp .components. Link to comment Share on other sites More sharing options...
C6 CYA Posted January 14, 2004 Share Posted January 14, 2004 aint got my car yet but have my system (its going i my bros car til i get mine) 2* atomic appocolypse 1500rms 12" subslanzar vibe 1800d amp 1800w rms infinity kappa comps 120w i thinkinfinty 6*9's 100w rms pheonix gold xs4600 amp 150w rms per channelalpien 78 summet or other headunit Link to comment Share on other sites More sharing options...
DaveRedEscort Posted January 14, 2004 Share Posted January 14, 2004 what watts are we talking about? peak? rms? and at what ohms? Link to comment Share on other sites More sharing options...
C6 CYA Posted January 14, 2004 Share Posted January 14, 2004 rms for me it should hit about 160 db Link to comment Share on other sites More sharing options...
C6 CYA Posted January 14, 2004 Share Posted January 14, 2004 saying that iive gone spl crazy before my bro had an alpine 10" type s and that was amazing to say it was only a 10" Link to comment Share on other sites More sharing options...
DaveRedEscort Posted January 14, 2004 Share Posted January 14, 2004 rms for me it should hit about 160 db what ohms is that RMS at mate? i've got:3 x Audiobahn 12" 2000watt RMS @ 1ohm subsgetting Pro-Plus Nemesis to power them (2000watt RMS @ 1 ohm)2 x JBL 6x9s 120watt RMS @ 4ohmKicker 2 x 120watt RMS @ 4ohm amp powering themthen just running compos off the HU Link to comment Share on other sites More sharing options...
C6 CYA Posted January 14, 2004 Share Posted January 14, 2004 is ur system safe running it at 1 ohms?? Link to comment Share on other sites More sharing options...
DaveRedEscort Posted January 14, 2004 Share Posted January 14, 2004 well i havn't got the amp yet so i dont know it might make the car cut out at 1 ohm but i'll sort that when the time comes, probably need a new battery or 2 Link to comment Share on other sites More sharing options...
g-spot Posted January 15, 2004 Share Posted January 15, 2004 lanzar 1200d 1200watt rms at 1ohmatomic apocalypse 15" 2500 wattlanzar cadnium front components 400watt (i think)lanzar 400 watt 4channelpioneer 6400 good for well over 140 db G Link to comment Share on other sites More sharing options...
sime73 Posted January 15, 2004 Share Posted January 15, 2004 alpine h/u 4x60w alpine mrd m500 900 w peakvibe vp2 amp 2x200w peakvibe 6x9 2x300w peakvibe cbr10 2x300w peakalpine 6" door speakers 2x80w peak but just got some alpine typr r components 2x150w peak to replace them we need more subs captain Link to comment Share on other sites More sharing options...
Blinkybill Posted January 15, 2004 Share Posted January 15, 2004 Got HU powering standered front speakers ( about 10-15wrms ) ( hay its my parents car ! ) Then 1100wrms @ 1ohm to a single. Hit 146.9dB and second loudest in the contry at the moment Link to comment Share on other sites More sharing options...
Blinkybill Posted January 15, 2004 Share Posted January 15, 2004 OHHH and DaveRedEscort, i would def recomend u get a second battery, upgrade The Big Three because ProPlus Memisis are known to give up the ghost if the power supply is'nt up to it, also consider getting the alt rewond if u will beadding more amps. One more thing, are those subs rated at 2000wrms each ? or is that there rating added togeather ? Link to comment Share on other sites More sharing options...
Troy Revill Posted January 16, 2004 Share Posted January 16, 2004 my mates focus what we built the system in... Ran in a sound off at source sounds 3 days after it had all been put in.. it ran 122.6db this was before we had chance to set everything up including the comps n what not.. he has 2 db audio squares cant rember all details on em its been a while...1000W american Lececy AmpAmerican Legecy 5 1/2 compsAmerican Legecy 6 x 9's in the rear doors... to come Comps and 6 x 9's all wired up to seperate Amps... And 2 more db squares to be added soon BOOM Should imgine when its next tested over 130db hopefully Link to comment Share on other sites More sharing options...
Blinkybill Posted January 16, 2004 Share Posted January 16, 2004 my mates focus what we built the system in... Ran in a sound off at source sounds 3 days after it had all been put in.. it ran 122.6db this was before we had chance to set everything up including the comps n what not.. he has 2 db audio squares cant rember all details on em its been a while...1000W american Lececy AmpAmerican Legecy 5 1/2 compsAmerican Legecy 6 x 9's in the rear doors... to come Comps and 6 x 9's all wired up to seperate Amps... And 2 more db squares to be added soon BOOM Should imgine when its next tested over 130db hopefully Adding 6X9" and component systems wont add to your dB. dB is Bass, not full range. To get the highest score u need to play a sine wave, that is at the frequency your car peaks at, this is called the res freq. U will need a DB meter to find it out but most cars are in the 50-60hetz area. Play one of these tones and u will get a louder score, tern off other amps that don't play bass as these are just drawing not wanted current from the battery. HTH If u wont any more advice on SPL ( my main subject ) Link to comment Share on other sites More sharing options...
