marcus Posted August 13, 2004 Share Posted August 13, 2004 i know its in the wrong place but i need an answer ASAP please OK, i have changed over my dials today and when i got them in the airbag light started flashing, it flashes 4 times in each cycle, what does this mean??? i tried putting my old dials in and there was no bulb in so i wanna get it sorted ASAP Please helpMarcus Link to comment Share on other sites More sharing options...
jonnybelfast Posted August 13, 2004 Share Posted August 13, 2004 Go to a garage with a plug in diagnostic tool to be safe you don't want that going off when you're driving!! Link to comment Share on other sites More sharing options...
plumber60 Posted August 14, 2004 Share Posted August 14, 2004 all im getting from ford is get it to then asap and get it checked cos there is a fault Link to comment Share on other sites More sharing options...
marcus Posted August 14, 2004 Author Share Posted August 14, 2004 sorted thank fook i pulled both connectors for the pre-tensioners off, sprayed them with WD40, left for 20 mins, plugged them back in and wella. the light no longer flashes Marcus Link to comment Share on other sites More sharing options...
rfcrangers Posted August 14, 2004 Share Posted August 14, 2004 yes thats what ford do when you take it in and charge you a bloody fortune. Link to comment Share on other sites More sharing options...
Ex-Finesse Posted August 14, 2004 Share Posted August 14, 2004 i pulled both connectors for the pre-tensioners off, sprayed them with WD40, left for 20 mins, plugged them back in and wella. the light no longer flashes I woulda taken the bulb out Link to comment Share on other sites More sharing options...
marcus Posted August 14, 2004 Author Share Posted August 14, 2004 i pulled both connectors for the pre-tensioners off, sprayed them with WD40, left for 20 mins, plugged them back in and wella. the light no longer flashesI woulda taken the bulb out but if the bulb is flashing it meanns the airbag wont go off so id rather fix it like i did Marcus Link to comment Share on other sites More sharing options...
M4TT Posted August 14, 2004 Share Posted August 14, 2004 i pulled both connectors for the pre-tensioners off, sprayed them with WD40, left for 20 mins, plugged them back in and wella. the light no longer flashesI woulda taken the bulb out but if the bulb is flashing it meanns the airbag wont go off so id rather fix it like i did Marcus me to, happened to me a while back Link to comment Share on other sites More sharing options...
