cargy Posted February 27, 2005 Share Posted February 27, 2005 Like DK Red mk5 I'm midway thru doing my fogs. I gave up with the existing loom as I couldn't find out for certain where the relay goes in the existing fusebox. I've cut into the loom for the F/Fog switch and got a feed for the lights' relay and the illumination all OK, and the lights work fine but I can't get the indicator in the poxing switch to work. It could be a duff switch, but as theres a 3rd pin (5th if u count the lighting feed & earth) I suspect it might bring a feed thru to make the warning lamp work. Would one of you nice chaps'chapesses with a multimeter and a few minutes to spare check this for me as I'd like to get the last bit done! Muchas Grazious The Cargy Link to comment Share on other sites More sharing options...
matt1295 Posted February 27, 2005 Share Posted February 27, 2005 you need a feed from the live to the fog lights (if u unda stand) that then illuminates the switch light Link to comment Share on other sites More sharing options...
cargy Posted February 27, 2005 Author Share Posted February 27, 2005 you need a feed from the live to the fog lights (if u unda stand) that then illuminates the switch light<{POST_SNAPBACK}> You're a diamon geezer So the 3rd wire makes the warning lamp work. Now I can get the job done proppa Link to comment Share on other sites More sharing options...
Drk_red_Mk5 Posted March 7, 2005 Share Posted March 7, 2005 Cool. I was gettin a little bit wound up with my one. Im now on my 3rd one due to getting annoyed at it. Link to comment Share on other sites More sharing options...
