Timmy C Posted May 13, 2005 Share Posted May 13, 2005 Ive noticed that my si has less pulling power below 3k RPM than my TDi had. I presume its because it has less tourque. Are their any particularly good mods for significantly increasing low rev power and the pick up on revs because i miss the kick in first gear that my diesel used to give. Link to comment Share on other sites More sharing options...
Rob84 Posted May 13, 2005 Share Posted May 13, 2005 Ive noticed that my si has less pulling power below 3k RPM than my TDi had. I presume its because it has less tourque. Are their any particularly good mods for significantly increasing low rev power and the pick up on revs because i miss the kick in first gear that my diesel used to give.<{POST_SNAPBACK}> 25 shot of nitrous Link to comment Share on other sites More sharing options...
Ex-Finesse Posted May 13, 2005 Share Posted May 13, 2005 You're not meant to use nitrous unless you've got the throttle wide open. It's also a bad idea to use it when you're low down in the rev range - Si's opinion was only after 3.5k revs To be honest Tim, the zetec is a 16v motor, and they're fundamental flaw is low down torque. It's an engine which works better when it's revving. I wouldn't be flat out in 1st below 3k revs...... If I wanted to accelerate quickly in 1st, I'd have the clutch half dis-engaged and rev the engine to more like 5k rpm! Link to comment Share on other sites More sharing options...
steve_sport_scort Posted May 14, 2005 Share Posted May 14, 2005 Ive noticed that my si has less pulling power below 3k RPM than my TDi had. I presume its because it has less tourque. Are their any particularly good mods for significantly increasing low rev power and the pick up on revs because i miss the kick in first gear that my diesel used to give.<{POST_SNAPBACK}>its a good question, there must be something that'll improve it,or did Gran Turismo lie to me about easy upgrades for cars Link to comment Share on other sites More sharing options...
Timmy C Posted May 14, 2005 Author Share Posted May 14, 2005 How about a small turbo will that kick in straight away. Im not really that bothered about max bhp to tell you the truth. I wouldnt beable to do a turbo for ages tho. far too expensive, unless i could use a small trubo with my current pistons and compression?? Link to comment Share on other sites More sharing options...
Rob84 Posted May 14, 2005 Share Posted May 14, 2005 How about a small turbo will that kick in straight away. Im not really that bothered about max bhp to tell you the truth. I wouldnt beable to do a turbo for ages tho. far too expensive, unless i could use a small trubo with my current pistons and compression??<{POST_SNAPBACK}> if you used a de-comp plate, u'd be able to run a bit more boost and make the turbo more worth while..... or you could spunk £400 ish on some forgies and crank it up some more. crank and rods are good for it. then get your self a RST manifold and turbo and aftermarket management and ur away. give or take a fuew bits obviously. your still looking at around £2k minimum for a good job Link to comment Share on other sites More sharing options...
Rob84 Posted May 14, 2005 Share Posted May 14, 2005 best thing to do would be to speak to Ian Howell, THE god of zetec turbo'ing. he'll steer you in the right direction. 01522 877887 Link to comment Share on other sites More sharing options...
Timmy C Posted May 14, 2005 Author Share Posted May 14, 2005 Iv not really got the kind of money required at the moment, could be worth me looking into in 6 months time. Link to comment Share on other sites More sharing options...
