is it possible to fit st170 rear brakes on a 97 escort, the kit comes with hubs, bearings, discs and pads.....they were remoived from a st after 25.000 miles after it was totalled!....
i was thinking about doing this, and most people i asked said its not possible,
but i went to my local scrappy a few days back and looked at a few ford rear disc setups on different cars, the scorpio ones fit, the have the hub attachments on, but its just mounted on a different angle, so the scorpio hubs would fit, but the caliper would be at the top facing down,
you might be able too, i know you can get brakets made for the for about £200,
you might be able to make a braket or mod you axle yourself,
but i havent got any st brakes to look at,
let me know how it goes if you try anything mate, cos its something id love to do
good luck :))
mmmm, really need to see the stub axle then
yeah iv been tying to find a set to have a look at, but you need some that have been taken off really,
but i really dont see why you couldnt do it,
would just need alot of modding to fit,
yeah tey fit stright one with spacing the caliper out a bit with some washers, pm sime73 on here for help
They're talking about the rear brake setup matt......
As it's a completely different suspension setup, I'd just stick to what's been already done on escorts - your choice is wide enough! :cheers:
