basskiddanny Posted June 16, 2005 Share Posted June 16, 2005 Right heres the problem: When i try to indicate there is no response from the car atall, no noise, not lights inside the car, no lights outside the car. I tried putting on the hazard warning lights and still nothing atall.... The rest of the controls on that stalk work like full beam and headlights... Checked the fuse and its fine When i activate or deactivate my Toad AI606 alarm the indicators flash as usual Can anyone help because people just think your a T*at if you dont indicate. Cheers. Link to comment Share on other sites More sharing options...
ANDYC Posted June 16, 2005 Share Posted June 16, 2005 probly the relay because the alarm will be wired in after the relay Link to comment Share on other sites More sharing options...
basskiddanny Posted June 16, 2005 Author Share Posted June 16, 2005 When i press the button for my alarm while sitting in the car i hear a clicking noise as the indicators flash...... Wouldnt that mean that the relay is working? Link to comment Share on other sites More sharing options...
ANDYC Posted June 16, 2005 Share Posted June 16, 2005 posibly just stuck Link to comment Share on other sites More sharing options...
basskiddanny Posted June 16, 2005 Author Share Posted June 16, 2005 which is probly stuck mate? If you mean the relay and i replace it will it probably fix it. Link to comment Share on other sites More sharing options...
ANDYC Posted June 16, 2005 Share Posted June 16, 2005 which is probly stuck mate? If you mean the relay and i replace it will it probably fix it.<{POST_SNAPBACK}>take the relay out give it a tap and try it again Link to comment Share on other sites More sharing options...
basskiddanny Posted June 16, 2005 Author Share Posted June 16, 2005 thgat sorted it cheers scort Link to comment Share on other sites More sharing options...
ANDYC Posted June 16, 2005 Share Posted June 16, 2005 no probs Link to comment Share on other sites More sharing options...
