chris_nuneaton Posted June 17, 2005 Share Posted June 17, 2005 Any suggestions on a steering problem I have? Intermittantly the steering will feel like the front tyres are flat, and when you come to a stop the steering will pull to one side (can be either depending on camber of road!) I’ve experimented with tyre pressures but no difference and I’ve changed the lower arms as well. Drop links were suggested, but I would have thought I’d be getting knocking noises over bumps, and the rubbers look ok on them!This is sending me mad, so any ideas to try would be appreciated! its a '97 1.6 lx by the way Cheers,Chris Link to comment Share on other sites More sharing options...
Devboy Posted June 17, 2005 Share Posted June 17, 2005 right, it's doing what my escorts does!!!! Have u checked the tyres? I was told it could be the calipers so replaced em anyways still did it :S then was told it could be the master cyclinder. so um.......... try that if it doesn't work when you finally figure it out tell me what it was! P.S. I'm replacing my tyres next week so will find out if it was that. However! sicne the crash i have replaced other bits to tehehehe. Link to comment Share on other sites More sharing options...
chris_nuneaton Posted June 17, 2005 Author Share Posted June 17, 2005 I think I can cross tyres off the list, as it did it with the original orrid steelies that were on it when i got the car, and its still doing it with a set of alloys & tyres that had done less than 1k when I fitted them a couple of weeks ago I did change the disks and pads last week and the calipers seemed to move freely For the price of them I may change the drop links anyway and cross them off the list of possibles Link to comment Share on other sites More sharing options...
plumber60 Posted June 17, 2005 Share Posted June 17, 2005 Any suggestions on a steering problem I have? Intermittantly the steering will feel like the front tyres are flat, and when you come to a stop the steering will pull to one side (can be either depending on camber of road!) I’ve experimented with tyre pressures but no difference and I’ve changed the lower arms as well. Drop links were suggested, but I would have thought I’d be getting knocking noises over bumps, and the rubbers look ok on them!This is sending me mad, so any ideas to try would be appreciated! its a '97 1.6 lx by the way Cheers,Chris<{POST_SNAPBACK}>4 wheel laser tracking, wheel balancing, worn shocks? Link to comment Share on other sites More sharing options...
