94 ELX Posted June 19, 2005 Share Posted June 19, 2005 I'm having a hard time trying to find a place to run my power wire through the fire wall any ideas or picture would be great thanks alan Link to comment Share on other sites More sharing options...
F1ACK Posted June 20, 2005 Share Posted June 20, 2005 I ran mine through a hole which is just behind the glovebox, it has a rubber bung in it, if you pop that out make a hole through it then you can feed the wire throughand not lose the water seal which you NEED! the wire will come out in the wheel arch (watch you don't pass it through the suspension spring) then it can be taken to the front of the engine bay wheel arch and up to the battery. Only pic I can show is this one, the light blue lines go through to the inside of the car. Link to comment Share on other sites More sharing options...
