C6 CYA Posted August 22, 2005 Share Posted August 22, 2005 how do you get the power cable through to the engine bay on a mk3 fiesta all the rest of hte system is wired up bar this as we can see no gromits or holes to get the power cable through cheers Link to comment Share on other sites More sharing options...
Muzz Posted August 22, 2005 Share Posted August 22, 2005 We couldnt find any when we did my mates so ended up drilling a hole through the bulkhead . Link to comment Share on other sites More sharing options...
Madmax Posted August 22, 2005 Share Posted August 22, 2005 On the passenger side under the scuttle panel ther is a very small hole in to the car which leads in2 the car behind the passenger side behind the air vent where u shuld be able to pull it thru. If u need more help then add me on msn and i'll xplain beta Link to comment Share on other sites More sharing options...
theresa Posted August 22, 2005 Share Posted August 22, 2005 On the passenger side under the scuttle panel ther is a very small hole in to the car which leads in2 the car behind the passenger side behind the air vent where u shuld be able to pull it thru. If u need more help then add me on msn and i'll xplain beta <{POST_SNAPBACK}> Agreed Yes, that's how I fed my cables through, as I couldn't find another way of doing it. It's easy to do, once you have found it. Link to comment Share on other sites More sharing options...
