gtipete Posted November 25, 2002 Share Posted November 25, 2002 Hi people, can any one give me some advise on where to stick the mesh to on the upper grill on a Mk6 Escort...If you take out the ford plactic grill then it leaves a gaping hole with no where to stick ur mesh to? Link to comment Share on other sites More sharing options...
Rich Posted November 25, 2002 Share Posted November 25, 2002 i have just done mine and the best way i found was to Cut a piece of mesh the width from headlight to headlight and plus 5cm ontop and under the size of the hole feel along the inside of the bumper at the top where the mesh sits. on mine there is enough room for my mesh to fit in. Bend the mesh into a L shape and slot the lower part of the L under the bumper. Bend the top of the mesh back towards the engine bay and secure the edges to the top of the mounting points on the headlights Note: make sure to get the sizes correct, i closed my bonnet onto the mesh and crushed it, it now has slight imprefections throughout the mesh This is the easiest way i found to do it IMO, if you check the how to section there is another suggestion Good luck, if u need help, email me Rich Link to comment Share on other sites More sharing options...
gtipete Posted November 25, 2002 Author Share Posted November 25, 2002 cheers mate, il have a look at what uv said Link to comment Share on other sites More sharing options...
Mr_Tom Posted December 11, 2002 Share Posted December 11, 2002 I took my original ford grill and bent the mesh round it then took it out and screwed it with the screws tht hold on the original grill and it looks great, and it dont budge either i'll av to get a pic, its ok until you openthe bonnet and i havent tidyied it up on the inside but hey ppl dont see that part Link to comment Share on other sites More sharing options...
