suprafinnon Posted September 20, 2006 Share Posted September 20, 2006 the drivers window doesnt work on this escort. the pass one works no bother. ive cleaned the switch up with some contact cleaner. any ideas? sometimes it works intermitently. usually i hold the button in for a bit then it will work but recently its not working at all. could i have a motor with some crap inside of it? cheers Paul Link to comment Share on other sites More sharing options...
Dave C Posted September 22, 2006 Share Posted September 22, 2006 could be a connection,or switch.Try plugging the driver side plug into the passenger switch,& visa versa. If the passneger side works,via the drivers switch,it'll be a connection,if not,it'll more than likely be the drivers switch. Link to comment Share on other sites More sharing options...
suprafinnon Posted September 23, 2006 Author Share Posted September 23, 2006 could be a connection,or switch.Try plugging the driver side plug into the passenger switch,& visa versa. If the passneger side works,via the drivers switch,it'll be a connection,if not,it'll more than likely be the drivers switch.ok will try that. cheers Link to comment Share on other sites More sharing options...
Devboy Posted September 23, 2006 Share Posted September 23, 2006 I had this, pull the switch out, and have a look at the connector block it might need a new connector block, mine did. Link to comment Share on other sites More sharing options...
theresa Posted September 23, 2006 Share Posted September 23, 2006 Mine did this and I tried swapping the switches, etc, etc. Was the motor in the end. Link to comment Share on other sites More sharing options...
