st4 Posted September 21, 2006 Share Posted September 21, 2006 What does everyone think of these? Ive been wondering about buying them for months but don't quite know yet... Is it just a poor mans coilover or would it actually be any good (considering they have been welded onto the right place on the strut)? Also what spring length would I need to use as they have from 7" long to 14" long. Im guessing the 7" one would make your car extremely low, especially when you adjust it aswell. Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
Madmax Posted September 21, 2006 Share Posted September 21, 2006 Tbh i would just get a decent set of coilovers, i cant believe that they would be anywhere near the same quality as a kit thats been properly designed. Link to comment Share on other sites More sharing options...
Scotteh Posted September 21, 2006 Share Posted September 21, 2006 i thort the same thing.....till i saw it wud be 1500 quid for a tein kit Link to comment Share on other sites More sharing options...
Madmax Posted September 21, 2006 Share Posted September 21, 2006 I know what ya mean, coilover kit that im after is around 650 lol bit pricey. Obviously nowher near your kit though thank god Link to comment Share on other sites More sharing options...
ScORTED Posted September 21, 2006 Share Posted September 21, 2006 i picked up some refurbed avo coil overs for £200 and they are fantastic - coilover conversions nah i wouldn't bother, the conventional wisdom is that they aren't very good Link to comment Share on other sites More sharing options...
st4 Posted September 21, 2006 Author Share Posted September 21, 2006 thats the thing though...prices! I can no-where near afford 650 quid that they want for coil overs for my scort so for the price equivalent I could do with these really. The two main benefits of these over uprated shocks and springs is: a) the price and b) I would be able to set the height of my car to what I want I'm not really bothered about performance at the moment as I'm not going to be throwing my car round corners when it's finished anyway because if I did end up crashing then I would have no money to fix it I probably will end up buying this kit but I'm not sure what spring size to go for, they're all 2.25" wide but what length spring will I need? I will be having either 16" or 17" alloys, spaced out about 25mm to meet the cossie arches, so any ideas? I dont want it bottoming out and the wheels hitting the fibreglass arches. Link to comment Share on other sites More sharing options...
mk1dub Posted September 21, 2006 Share Posted September 21, 2006 a) the price Dont forget you will need someone to weld them on precisely, it's not the most ideal component that you want someone to make a bodge of. b) I would be able to set the height of my car to what I want The only problem with that is the dampers and the springs wont be matched, so you may end up with a bumpy, crashy ride, or a very wollowy one, possibly even a combination of all three. I probably will end up buying this kit but I'm not sure what spring size to go for, they're all 2.25" wide but what length spring will I need? A bit of an unknown as it will depend on the ride height and also the need to factor in helper springs if needed. Someone may have the info and if anyone, Burton Power should be able to help. Personally I would go for coilovers, plenty of choices out there suiting various budgets. Minimum I would go for is a matched shortened damper and spring combo, if you need to go lower, cheap coilovers. More often than not they are cheap for a reason but on the whole should offer a better ride quality. Secondhand coilovers maybe? Link to comment Share on other sites More sharing options...
ScORTED Posted September 21, 2006 Share Posted September 21, 2006 agreed - like i said mine were£200 and they rock! plus once the dampers wre out - which they will quickly you'll need the kit rebuilding and rewelding! Link to comment Share on other sites More sharing options...
