Audio Volume Problem
37 replies to this topic
#1 ScottSummerhayes
ScottSummerhayes
  • Drives:2003 Audi A3 1.8T Sport
Posted 31 July 2008 - 10:21 AM
Hello Everyone, Just installed all my new ICE. I did it part by part and finally finished it off last night with fitting the Front Component speakers. I seem to have a slight problem....
Basically they are really really quiet. I had one side all done and was listening to the difference between the stock ford and the ones i just installed. And personally the stock ford speakers were way way louder!
Normally on my headunit volume level "30" is what i always put it on when listening to music pretty loud (and it is) but now all i can hear is bass due to my Sub+Amp over powering the front speakers. This was NEVER the problem before changing them :( It was acutely the other way round, i was thinking of turning the gain up on the amp!
Im pretty disappointed because i was expecting much cleaner and vibrant audio when up loud (stock for speakers would distort) and there pathetic...
Just to note how bad it is, i picked my girlfriend up and she put on one of her fav songs and turn't it up to the normal loud setting of "30" she then looked at me and said "what have you done to your car, all i can hear is the bass no vocals etc...." That coming from a dizzy blonde must mean something.......
Heres what i got:
Pioneer Deh-P6000ub Head unit (50x4 peak)
FLI Comp 6 intergrator (85w RMS / 90db)
Stock ford wiring w/adaptor plates
JLB Sub and Amp
Help please guys :( I won't want to stick the ford units back in and waste my new £60 components
Just noticed that on the FLI website it says:
Minimum input: 45W RMS
Is this the reason why? obviously my 50w peak headunit is going to do 45w rms (prob about 20-25)
#2 MC_Bob
MC_Bob
  • Drives:1.8 Escort Ghia X Building: RS2000 Cabriolet (Finished!)
Posted 31 July 2008 - 10:30 AM
Running aftermarket speakers off the headunit is a bad idea. Stock speakers are more efficient then others. Your headunit only puts out around 15-20WRMS.
Get an amplifier for them.
2.0 RS2000 Cabriolet
1.8 Zetec
#3 ScottSummerhayes
ScottSummerhayes
Posted 31 July 2008 - 11:23 AM
Please explain to me why its a bad idea? if so why do headunits have speaker connections and not just RCA....
I guess there is no other way other than another amp? I really dont have the room/money for another one!
F U C K sake
#4 MC_Bob
MC_Bob
Posted 31 July 2008 - 11:28 AM
Because aftermarket speakers are designed to run with higher power, hence the greater RMS ratings. Headunits have speaker connections for the reason you used them before.
1.8 Zetec
#5 Danny1107
Danny1107
Posted 31 July 2008 - 11:30 AM
you only need a 2x100w amp a budget one would do fine, and you could put one the amp under a seat or even in the glove box :)
#6 Tez162003
Tez162003
  • Drives:Nissan 350Z (the fuel guzzler), Corsa B 1.2 (the thing stopping me constantly using said fuel guzzler)
Posted 31 July 2008 - 11:31 AM
amp them, they will sound 100 times better! then you can also control the voloumes seperatly for sub and speakers,
i have 2 amps in mine
AMP 1 - 2 x 12" subs
AMP 2 - 4 6.5" coaxials (2 in each door) and for me having amped speakers in the front like that is the best option, i dont like having all the amped speakers at the back, sounds crap!
just buy a small amp 2 channel will do! then you can play it at your usual volume and set the bass and speaker volumes on each amp to get the best sound!
#7 ScottSummerhayes
ScottSummerhayes
Posted 31 July 2008 - 11:48 AM
Looks like im going to have to amp them! more bloody money....
Guess i will stick the amp under the seat, so its nice and close for the wiring!
How would i go about wiring up a 2nd amp? obviously i have power coming into the car but im going to have to re-run another right? The one now wouldn't be man enough, and they just splise off the remote power and connect the RCA's up....Plus then run all the wiring to the speakers... AHH SO MUCH WORK.
#8 MC_Bob
MC_Bob
Posted 31 July 2008 - 11:50 AM
I only use 50wx2 for my fronts which is loud enough tbh. You might get away with your current wiring and tapping into it as its run down the car. What size cabling is it, and what amplifier do you have running off it at the moment?
Watch ebay and you can probably pick an amp up for 15-30 quid.
1.8 Zetec
#9 Danny1107
Danny1107
Posted 31 July 2008 - 11:51 AM
another wiring kit or a power distribution block on your current wiring kit (providing the wire is thick enough) IIRC its best to use 4gauge from battery to distribution block then 8gauge from the block to the amps, then use seperate earths for each amp, remote cable either seperate or the same one, doesnt matter
#10 Tez162003
Tez162003
Posted 31 July 2008 - 11:52 AM
rather than 2 power wires etc coming off the battery best way:
Run 4gauge wire from battery to Distribution block which will be extra fuses for safety, then run 8 gauge to both amps, then run remote cable from one amp to the other in series, then seperate 8 gauge ground wires, sorted,
#11 MC_Bob
MC_Bob
Posted 31 July 2008 - 12:00 PM
How do you know 4 gauge will be enough? Id wait to find out what hes running first.
1.8 Zetec
#12 1pukkadeal
1pukkadeal
  • Drives:Anything that Start's
Posted 31 July 2008 - 01:49 PM
It may just be a match of your headunit and the speakers in the doors ,as not all aftermarket speakers need to be fed by an amp ,component ones however do sap a bit more power to get the frequency response and sound from them
#13 ScottSummerhayes
ScottSummerhayes
Posted 31 July 2008 - 02:10 PM
What do you mean a "match"...?
Im running amp wise a 300-400w RMS JBL GTO Powering a 300W RMS JBL Sub in Bridged mode. I think i will keep the wiring separate and just run another power cable. I just remembered that my headunit has 3 remote outs so i wont have to worry about them (one for each pre-out i guess...). Ground won't be a problem, just running the speaker wires.
I would rather buy new, used electricals is just asking for problems....
And i think the wiring i have now to my amp is 0guage (???)
Also, if the headunit is right-up it sounds pretty crappy. lots of clipping etc. Im sure this is because it is running at its max right? if it was amp'd will it sound better?
Thanks for all your help people
scotty
BTW: I just got a ride in the best Sierra Cossy in the country! I pretty much Shite my pants
#14 meekstaaa
meekstaaa
  • Drives:Citroen C4 VTS
Posted 31 July 2008 - 02:31 PM
I never had a problem with running my components via the HU. I would double check everything and also the settings on the HU, have you used any of the high pass or low pass filters? You should. Also i would rewire all the speakers with proper cable as that made a huge difference to mine!
Proudly pushing in front of people who dare to leave the smallest amount of space since 2002.
Now doing it in a Wicked Red Citroen C4 VTS 180.
#15 MC_Bob
MC_Bob
Posted 31 July 2008 - 02:50 PM
Headunit matched to the speakers? I kinda disagree with that, or maybe I dont understand what you mean.
If its 0guage thats great. You could get a T junction block to take an 8 or 4 guage cable to your new amp easily.
Ive never really had a problem with used amplifiers. Have a look on Talkaudio.com, theyre classifieds are very good.
Your headunit is just pretty much running out of power hence the clipped/disorted sound, the solution is pretty much more power :)
1.8 Zetec
