redmex Posted August 29, 2012 Share Posted August 29, 2012 Hi GuysIve got a mk5B rear disc beam to go in my mk6 Mexico.. Which handbrake cable should I be ordering?.. Seems to be more than one available for RS2000 and 3i rear beams TaSparkie Link to comment Share on other sites More sharing options...
Naylor2006 Posted August 30, 2012 Share Posted August 30, 2012 (edited) Hi GuysIve got a mk5B rear disc beam to go in my mk6 Mexico.. Which handbrake cable should I be ordering?.. Seems to be more than one available for RS2000 and 3i rear beams TaSparkie Yeh I know theres like 3 different lengths. Im pretty sure its the MK6 RS2000 cable for the RS2000 that had rear discs obviously, JC got me mine so if it is this one (hopefully someone will confirm) he has the part number somewhere which will sort you out. Edited August 30, 2012 by Naylor2006 Link to comment Share on other sites More sharing options...
redmex Posted August 30, 2012 Author Share Posted August 30, 2012 Hi GuysIve got a mk5B rear disc beam to go in my mk6 Mexico.. Which handbrake cable should I be ordering?.. Seems to be more than one available for RS2000 and 3i rear beams TaSparkie Yeh I know theres like 3 different lengths. Im pretty sure its the MK6 RS2000 cable for the RS2000 that had read discs obviously, JC got me mine so if it is this one (hopefully someone will confirm) he has the part number somewhere which will sort you out.CheersHopefully JC will pop in here with a answer soon I wonder if its this below?MK6 Cable Link to comment Share on other sites More sharing options...
Naylor2006 Posted August 30, 2012 Share Posted August 30, 2012 (edited) Hi GuysIve got a mk5B rear disc beam to go in my mk6 Mexico.. Which handbrake cable should I be ordering?.. Seems to be more than one available for RS2000 and 3i rear beams TaSparkie Yeh I know theres like 3 different lengths. Im pretty sure its the MK6 RS2000 cable for the RS2000 that had read discs obviously, JC got me mine so if it is this one (hopefully someone will confirm) he has the part number somewhere which will sort you out.CheersHopefully JC will pop in here with a answer soon I wonder if its this below?MK6 Cable PM him, he wont mind, he might not see the thread. So that ebay item is Part Number: 6676123 I searched on EVO and found http://www.escortevolution.co.uk/forums/in...&hl=6676123 which seems to suggest that thats a MK5 RS2000 cable, this is where my knowledge stops, not sure if this will work for you or not, might try find my post about which one I needed. Found it: http://www.escortevolution.co.uk/forums/in...2859&st=450 Different part number for MK6 mate, if the xr3i beam is the same to the rs2000, which im pretty sure it is, then the part number is in that link which is 1036202 Edited August 30, 2012 by Naylor2006 Link to comment Share on other sites More sharing options...
redmex Posted August 30, 2012 Author Share Posted August 30, 2012 Hi GuysIve got a mk5B rear disc beam to go in my mk6 Mexico.. Which handbrake cable should I be ordering?.. Seems to be more than one available for RS2000 and 3i rear beams TaSparkie Yeh I know theres like 3 different lengths. Im pretty sure its the MK6 RS2000 cable for the RS2000 that had read discs obviously, JC got me mine so if it is this one (hopefully someone will confirm) he has the part number somewhere which will sort you out.CheersHopefully JC will pop in here with a answer soon I wonder if its this below?MK6 Cable PM him, he wont mind, he might not see the thread. So that ebay item is Part Number: 6676123 I searched on EVO and found http://www.escortevolution.co.uk/forums/in...&hl=6676123 which seems to suggest that thats a MK5 RS2000 cable, this is where my knowledge stops, not sure if this will work for you or not, might try find my post about which one I needed. Found it: http://www.escortevolution.co.uk/forums/in...2859&st=450 Different part number for MK6 mate, if the xr3i beam is the same to the rs2000, which im pretty sure it is, then the part number is in that link which is 1036202cheersI will PM JC just to follow it up, but thanks for the help so far Here's the beast waiting in my trailer for overhaul.. God knows when I'll have the time, "building garage atm",but hey at least its here waiting http://www.evo-host.co.uk/getimg/29747.jpghttp://www.evo-host.co.uk/getimg/29748.jpg By the way this axle is from a L reg XR3i Cabriolet.. Shame the strut brace was different .. MK5 grrrrrrSparkie Link to comment Share on other sites More sharing options...
JC Posted August 30, 2012 Share Posted August 30, 2012 If fitting to MK6: Then a MK6 RS2000 handbrake cable was need to fit the beam, (differs from a MK5 one and Standard MK6) Ford part number: 1036202 that beam looks identical to mine sorry my PM's failed... tired! Link to comment Share on other sites More sharing options...
