2.0 Conversion Problem
51 replies to this topic
#1 foxdie
foxdie
  • Drives:2006 Fiesta ST
Posted 25 August 2005 - 08:10 PM
As you all know i had the op. All went swimmingly. Turns over but doesn't turn over. The coil isn't sending a spark. we tried another coil and that didn't work either. We changed the leads and plugs still nothing. Even called a mechanic round to check the wiring out. all fine. Only thing i can think of is the Crank sensor is faulty, so gonna swap that with my original 1.8 one.
Any ideas? the wiring is correct, plugs arnt in the wrong holes. and everything is wired up correctly, and all earths are... earthed. the coil just isn't sending a spark... c'mon solve my problem becuase i SOOO want to be able to drive to the in-laws this weekend :tired: :roll:
I was thinking the PATS is kicking in, but i think that affects the fueling not the ignition. so im lost...
#2 ANDYC
ANDYC
  • Drives:s2rst , puma 1.7 ,sierra saphire
Posted 25 August 2005 - 08:16 PM
mate that is what mine was doin and it was two wires that are identicle and right next to each other had 5 other people look at mine to see why it wouldnt start is your crank sensor on the front???
#3 sortedford
sortedford
  • Drives:TROCSE DROF A
<{POST_SNAPBACK}>
:roll:
Stickers, Sparkplug Covers etc.. Visit the EVO shop here !!!
Florida Rental Villa- Sleeps 12!
All posts are the view of the writer, and not necessarily that of escortevolution.co.uk/ feoc.co.uk
#4 foxdie
foxdie
Posted 25 August 2005 - 09:01 PM
<{POST_SNAPBACK}>
:roll:
<{POST_SNAPBACK}>
No one likes a Smart ass.
It turns over- but doesn't start.
I followed that wire and it goes to the ECU so i doubt its the wrong one. infact you come and fix i'll give your petrol money back :thumb:
#5 ANDYC
ANDYC
Posted 25 August 2005 - 09:08 PM
if i could get down i would mate but ive got no money till tuesday now
have you swaped the plugs around and tried it ????
have you got a test light
if so check if you are gettin a positive feed to your coil pack ill check which wire does what on mine tomorrow and let you know
#6 foxdie
foxdie
Posted 25 August 2005 - 09:13 PM
im not sure if the coils even getting power. That might be the problem, but i dont know how to test it. I pulled the lead/Plug out and tested it on the Cover, but its not sparing, so im not sure :S
#7 ANDYC
ANDYC
Posted 25 August 2005 - 09:17 PM
give me a minute just workin somet out
#8 ANDYC
ANDYC
Posted 25 August 2005 - 09:30 PM
does yours have edis under the bonnet
#9 John16v
John16v
  • Drives:Mk 6 2.0 5 door, Mk5 RS2000
i have the same kinda problem. does exactly the same when connecting the 2.0 ECU but works fine on the 1.6 ECU
WWW.GSMOTORSPORT.COM
WWW.REPAIRGEOT.CO.UK
WWW.ZOOMOTORSPORT.CO.UK
Mk5 Escort RS2000.
#10 ANDYC
ANDYC
Posted 25 August 2005 - 09:31 PM
<{POST_SNAPBACK}>
do you have external edis
#11 John16v
John16v
Posted 25 August 2005 - 09:36 PM
no a clue.....think the ecu might need it though
Mk5 Escort RS2000.
#12 ANDYC
ANDYC
Posted 25 August 2005 - 09:50 PM
you know when u try and start the car is the alarm light flashing
#13 John16v
John16v
Posted 25 August 2005 - 09:52 PM
cant remember...why?
Mk5 Escort RS2000.
#14 ANDYC
ANDYC
Posted 25 August 2005 - 09:54 PM
personally i think you both need the same ecu as ralph
i thought id just plug mine straight in without swaping wires and it ran fine which was strange
ive been looking through wiring diagrams and found that my wires are in different places to a mk6 my injectors are in pin numbers 58 59 39 35 only two of these match up to what ralph had to do on his conversion
my fuel pump wire is in number 1 different to ralphs
and wire 22 on mine is an earth not pats
#15 ANDYC
ANDYC
Posted 25 August 2005 - 09:56 PM
which means that differnt mondeos had different looms so i think u will be there forever and a day trying to match wires up
