escort si Posted May 7, 2003 Share Posted May 7, 2003 I have just fitted a set of pioneer 6*9's (330w) and a sony headunit CDX CA600X. When i turn the headunit up just passed half way the quality is pish!!!! Why is this? Link to comment Share on other sites More sharing options...
Chrissyboy Posted May 7, 2003 Share Posted May 7, 2003 you checked the settings on the radio Link to comment Share on other sites More sharing options...
escort si Posted May 7, 2003 Author Share Posted May 7, 2003 yeah. u mean like the bass , treble etc. It just doesnt seem to be able to handle it when i put it up loud! SHITE!!! My bro has got the exact same speakers with a pioneer headunit and it loud as FCuk!! Link to comment Share on other sites More sharing options...
Alan Escort SI Posted May 15, 2003 Share Posted May 15, 2003 I have just fitted a set of pioneer 6*9's (330w) and a sony headunit CDX CA600X. When i turn the headunit up just passed half way the quality is pish!!!! Why is this? if you dont wire the 6X9s up rite on the shelf they cancle each other out and sound shite wire one speaker the rite way and the other wrong see how that sounds, thought it was weird but it worked for me Link to comment Share on other sites More sharing options...
Rich Posted May 15, 2003 Share Posted May 15, 2003 if you dont wire the 6X9s up rite on the shelf they cancle each other out and sound shite wire one speaker the rite way and the other wrong see how that sounds, thought it was weird but it worked for me that is because the audio signal is tell the speaker to go out but its coming in instead, so u get the reverse effect of the sound. Although i thought speakers have different size connectors on the + and - to prevent this also put all the settings, bass and trebble to 0 and try the volume on its own see how loud that goes before the quality drops Link to comment Share on other sites More sharing options...
escort si Posted May 15, 2003 Author Share Posted May 15, 2003 I have just fitted a set of pioneer 6*9's (330w) and a sony headunit CDX CA600X. When i turn the headunit up just passed half way the quality is pish!!!! Why is this? if you dont wire the 6X9s up rite on the shelf they cancle each other out and sound shite wire one speaker the rite way and the other wrong see how that sounds, thought it was weird but it worked for me i dont understand what u mean. there is only one way possible to wire the speakers up. they are both wired up correctly. Link to comment Share on other sites More sharing options...
Rich Posted May 15, 2003 Share Posted May 15, 2003 i dont understand what u mean. there is only one way possible to wire the speakers up. they are both wired up correctly. The speakers have a + and - terminal with different connectors on. However wen you took the old speakers out and snipped off the ford terminals, u may of connected the + wire on the speakers to the - wire in the car. Link to comment Share on other sites More sharing options...
Ringo_Mountbatten Posted May 15, 2003 Share Posted May 15, 2003 This could also be because you're trying to power up 330w speakers but your head unit is only providing you with 50w per channel. You might want to invest in an amp if you want loud, crisp, clear sound. Link to comment Share on other sites More sharing options...
Alan Escort SI Posted May 17, 2003 Share Posted May 17, 2003 This could also be because you're trying to power up 330w speakers but your head unit is only providing you with 50w per channel. You might want to invest in an amp if you want loud, crisp, clear sound. It shouldnt matter even if u have an amp its like Rich said:- (The speakers have a + and - terminal with different connectors on. However wen you took the old speakers out and snipped off the ford terminals, u may of connected the + wire on the speakers to the - wire in the car.) Even on an amp it will be the same Just try wiring one speaker rite one wrong it WONT do any damage and see the difference in sound. sound should have more bass. Even if your head unit is 50 watts should still sound quite nice, Mine does Link to comment Share on other sites More sharing options...
Rich Posted May 17, 2003 Share Posted May 17, 2003 gawd i was right again, whats going on Link to comment Share on other sites More sharing options...
escort si Posted May 17, 2003 Author Share Posted May 17, 2003 thye seem to be fine now. i am gonnae get new front speakers for my m5 escort. what size are they and an1 got any recommendations? also do they make alot of deference? Link to comment Share on other sites More sharing options...
