MC_Bob Posted March 6, 2009 Share Posted March 6, 2009 I noticed a few poeple here have done it, and Ive gotta put one into the white escort soon. Does anybody have any schematics etc? It seems easy enough, but some parts of the manual have confused me. Ta Link to comment Share on other sites More sharing options...
bongo Posted March 8, 2009 Share Posted March 8, 2009 got these written down,cant remember exactly whats what but here goes. fuel pump cut= bl+red in car (drivers kick panel) 2 blues on alarm accessory=yellow in car (ignition harness) white + green on alarm central locking=lock=thick yellow+red in car,b on alarm (not sure if b is brown or black?) unlock= 1st thick white+red in car,b+w on alarm door trigger=door pin wire,pink on alarm boot release=thin b+red under boot switch,g+y on alarm auto door lock= wire on brake pedal,brown on alarm? indicators=blue+white and blue+red in first black multiplug on top of fusebox main power i just connected straight to battery earthed at bottom of a pillar. hope this helps,not quite sure on some of the above so double check things. Link to comment Share on other sites More sharing options...
MC_Bob Posted March 8, 2009 Author Share Posted March 8, 2009 Thank you so much, will deffo report back. Thanks! Link to comment Share on other sites More sharing options...
Gonzo0 Posted March 9, 2009 Share Posted March 9, 2009 Top alarm the SA30 Bargain at £50 as well Link to comment Share on other sites More sharing options...
MC_Bob Posted March 9, 2009 Author Share Posted March 9, 2009 Where do you lot mount the module, behind the dash or near the ecu? Ta Link to comment Share on other sites More sharing options...
MC_Bob Posted April 19, 2009 Author Share Posted April 19, 2009 Just finished it, buta problem has occurred. The alarm doesnt seem to know if a door has been opened, if I leave the window open, then arm the alarm and open a door through the window, it doesnt set it off.Aswell, it auto arms itself as soon as you finish driving, and goes off. I have a feeling its the pink wire for the door trigger, where should this be wired? I put it to the door switch on the frame. Thanks for your help guys! Link to comment Share on other sites More sharing options...
MC_Bob Posted April 20, 2009 Author Share Posted April 20, 2009 All fixed, had to put the pink wire on a wire going up the A pillar. The only thing now is, if you unlock the car, but open the handle too early, the car relocks, but the alarm thinks the car is unlocked. Any way of fixing this? Theres a few more wires not being used. Cheers Link to comment Share on other sites More sharing options...
MC_Bob Posted April 20, 2009 Author Share Posted April 20, 2009 Also, anyway to make the car deadlock? I noticed the alarm has a wire which gives out a -ve voltage when its armed, could this be for it? Thanks! Link to comment Share on other sites More sharing options...
bongo Posted April 20, 2009 Share Posted April 20, 2009 All fixed, had to put the pink wire on a wire going up the A pillar. The only thing now is, if you unlock the car, but open the handle too early, the car relocks, but the alarm thinks the car is unlocked. Any way of fixing this? Theres a few more wires not being used. dont open it too early lol Cheers Also, anyway to make the car deadlock? I noticed the alarm has a wire which gives out a -ve voltage when its armed, could this be for it? Thanks! think that could be used for a window closure kit or summin,does the output last for a certain time? like 45 sec? Link to comment Share on other sites More sharing options...
