jollin Posted March 17, 2009 Share Posted March 17, 2009 hi all put an rs turbo lump in my mk5 escort but its misfiring quite bad it was overfueling alot but i've now sorted this when u rev it its like its choking and sounds like its down on one cylinderive got spark and fuel in all cylinders it also backfires wen u rev it and spits flames out the exhaust! could realy do with some help from an rs turbo specialist!!! anyone know anybody who could help!?!?! cheers jay Link to comment Share on other sites More sharing options...
scortpower Posted March 17, 2009 Share Posted March 17, 2009 buy mine! have you got the leads the right way? also what fuel pump are you using? is the timing set right? Link to comment Share on other sites More sharing options...
escort4x4 Posted March 18, 2009 Share Posted March 18, 2009 get it to a rolling road, running like that engine is heading for melt down. rolling road tuners will dianose the problem and sort it for you at your expense Link to comment Share on other sites More sharing options...
tezmanian devil Posted March 18, 2009 Share Posted March 18, 2009 join passionford.com mate, im sure someone on there will be able to help Link to comment Share on other sites More sharing options...
jollin Posted March 18, 2009 Author Share Posted March 18, 2009 timing is spot on yeh leads are right way round 1342 innit?? on autodata program it says 1342 but my haynes manual says 1243!! which one is it??using my standard 1.4 fuel pump atm till i uprate it which is the best to use with the engine?? i managed to get it home but it was so painful it chokes alot, backfires, struggle to get it up to 40 ish den wont go past 50ish on a flat road!! Link to comment Share on other sites More sharing options...
tezmanian devil Posted March 18, 2009 Share Posted March 18, 2009 1234 mate, 1 being closest to the cam pully Link to comment Share on other sites More sharing options...
jollin Posted March 18, 2009 Author Share Posted March 18, 2009 ok m8 i'll give that a go Link to comment Share on other sites More sharing options...
jollin Posted March 18, 2009 Author Share Posted March 18, 2009 na didnt wanna know wouldnt even attempt to start! anyfing else?? Link to comment Share on other sites More sharing options...
tezmanian devil Posted March 18, 2009 Share Posted March 18, 2009 (edited) you have got the lead's connected right on the coil aswel havnt you? what is it, a escort turbo engine, or fiesta turbo? you sure you sorted it's overfeuling aswel, shouldn't spit flame's out if you have Edited March 18, 2009 by tezmanian devil Link to comment Share on other sites More sharing options...
jollin Posted March 18, 2009 Author Share Posted March 18, 2009 all the leads are the right way roundits an escort rs turbo enginei've sorted out the overfueling so shouldnt be overfueling now Link to comment Share on other sites More sharing options...
tezmanian devil Posted March 18, 2009 Share Posted March 18, 2009 i honestly dont know then mate, i had a fiest turbo engine in mine... i'd suggest giving torque of the devil a ring as they helped me out a great deal with my conversion. Link to comment Share on other sites More sharing options...
jollin Posted March 18, 2009 Author Share Posted March 18, 2009 lol its annoying me now ok m8 well cheers for all ur help!u gonna b at santa pod dis weekend?? Link to comment Share on other sites More sharing options...
Dubs Posted March 18, 2009 Share Posted March 18, 2009 Firing order should be 1342, 1 being the cambelt side, working round anticlockwise as you look at the dizzy from the passenger side Link to comment Share on other sites More sharing options...
Stu Posted March 18, 2009 Share Posted March 18, 2009 Fuel pump is the problem.. or at least, A major problem. Link to comment Share on other sites More sharing options...
scortpower Posted March 19, 2009 Share Posted March 19, 2009 as stu said the fuel pump is the problem, when they tried to run mine with the 1.4 fuel pump it would not even start, the 1.4 fuel pump does not have enough pressure get a uprated cossie pump in it then i bet it runs fine Link to comment Share on other sites More sharing options...
