dansGTI Posted April 3, 2009 Share Posted April 3, 2009 Right, i have a Sealey 1 ton foldable engine hoist/crane, and it isnt very old at all. And i have a problem with it! The problem started after the crane was laid down in the back of a transit, then it wouldnt work after this. The hydraulic ram has a fault, but its a strange one, if you lift the arm of the crane, it will stay up (and it will take the weight of an engine). BUT the crane will not pump up into this position, when you pump it, it goes up, but then goes back down again. But like i said, whatever valve is inside, the ram will stay up if you lift it manually. So the fault has to be in the little bit that pumps the fluid in. But like i said, its not that old! The only thing i can think of that may have caused it some problems, is it was left outside for a little bit in january............. (dont all call me a tw*t) But the hoist did work after being left outside anyway, admittedly not as well, but it did work. I have topped it right up with the correct hydraulic fluid because it thought it might have been low, no joy. Although i will say it took a massive amount of fluid!! Ive looked and i do not want to buy a new complete hoist, but if needs be i'll buy the ram, but its nigh on impossible to find somebody who will sell me just the ram. And i need it like, NOW! Its causing me a huge issue Link to comment Share on other sites More sharing options...
mr matty Posted April 3, 2009 Share Posted April 3, 2009 mine livs out side laid down !! works fine every time ! try getn a survice on the ram ! may be sumat n nowt ! Link to comment Share on other sites More sharing options...
hamspeed Posted April 3, 2009 Share Posted April 3, 2009 If its not that old surely its under warrenty still? If not have you tried Sealey themselves for spare parts? Sales & General Enquiries Tel (01284) 757 500 Fax (01284) 703 534 Email sales@sealey.co.uk Technical Hotline Tel (01284) 757 505 Fax (01284) 757 561 Fax Order Hotline Fax (01284) 767 626 Spares Fax (01284) 760 160 Accounts Tel (01284) 706 966 Fax (01284) 752 752 Link to comment Share on other sites More sharing options...
dansGTI Posted April 3, 2009 Author Share Posted April 3, 2009 mine livs out side laid down !! works fine every time ! try getn a survice on the ram ! may be sumat n nowt ! Hmmmm, then whats up with it, i thought the weather or laying down killed it. The pump part does work, its like a valve or summat wont hold the pressure, but the ram will stay up if i pull it up. The the only way to get it down is use the bleed screw as normal?!?!? If it was knackered, i would expect it to not go up at all, and just fall down again If its not that old surely its under warrenty still? If not have you tried Sealey themselves for spare parts? Sales & General Enquiries Tel (01284) 757 500 Fax (01284) 703 534 Email sales@sealey.co.uk Technical Hotline Tel (01284) 757 505 Fax (01284) 757 561 Fax Order Hotline Fax (01284) 767 626 Spares Fax (01284) 760 160 Accounts Tel (01284) 706 966 Fax (01284) 752 752 Thanks mate, will give them a call!! Link to comment Share on other sites More sharing options...
mr matty Posted April 3, 2009 Share Posted April 3, 2009 (edited) may have a faulty seal ?!? Edited April 3, 2009 by mr matty Link to comment Share on other sites More sharing options...
dansGTI Posted April 3, 2009 Author Share Posted April 3, 2009 Anybody know where would be a good place to take the ram to get repaired? Link to comment Share on other sites More sharing options...
Danzetec Posted April 3, 2009 Share Posted April 3, 2009 Have you bled the air out of the ram? By pulling the arm out you could of pulled air past the seal and this will give you probs Link to comment Share on other sites More sharing options...
mykez69 Posted April 3, 2009 Share Posted April 3, 2009 sounds like there is air blockage inside it fresh change of fluid and thats what fixed an engine crane for me once when we pumped it up it went up a cm or so then slowly back down it came, if you pushed it up with your hand it would stay there all we did was change fluid Link to comment Share on other sites More sharing options...
dansGTI Posted April 3, 2009 Author Share Posted April 3, 2009 sounds like there is air blockage inside it fresh change of fluid and thats what fixed an engine crane for me once when we pumped it up it went up a cm or so then slowly back down it came, if you pushed it up with your hand it would stay there all we did was change fluid Thats exactly what its doing! Now to work out how to change the fluid Link to comment Share on other sites More sharing options...
sutty2006 Posted April 3, 2009 Share Posted April 3, 2009 I have a manual fold up crane. Its older than me and lifted more engines out of cars than i can bear to think about. Its a tad bent now due to taking a V6 + auto box out of a granada all in one hehehe. Link to comment Share on other sites More sharing options...
