escortmk6 Posted April 16, 2009 Share Posted April 16, 2009 Just completed my rebuild on the CVH head. The car starts fine but has no power when going along. The car is auto and have checked all fluids, spark plug gaps, timing, spark. The car was doing this before the rebuild and broke down with a falure of the ignition module. I have since ordered a new dizzy and waiting for it to arrive. Anyone have any clue on what is causing it? Cheers Link to comment Share on other sites More sharing options...
adamGTI Posted April 16, 2009 Share Posted April 16, 2009 carb jets full up with crap? fuel pump weak? Link to comment Share on other sites More sharing options...
escortmk6 Posted April 16, 2009 Author Share Posted April 16, 2009 Carb is new, and recently cleaned. Not sure bout fuel pump? any way to test? Cheers Link to comment Share on other sites More sharing options...
stoney Posted April 16, 2009 Share Posted April 16, 2009 Yeah pull the pipe off between the pump and the carb get a friend to crank the engine if it pumps a fair amount of fuel out its work in ok. and new carbs often have swarf floating around in the float chamber blockin up jets and such like this aint un common especialy on a webber. if its a new carb has the mixture etc been set? also remove the pipe before the pump and also remove the fuel cap (when the tank is at low fuel level ) and blow an air line down there to make sure fuel lines aint blockin etc this also common on alder carb fords esp mk1 fiestas they have a coating wich comes of in side the tank floats around and partialy blocks the whole. what carb ar you runnin is it the standard 32 /34 degas webber? Link to comment Share on other sites More sharing options...
escortmk6 Posted April 16, 2009 Author Share Posted April 16, 2009 Its a VV carb, fuel line ok all unbloked, jets clear gonna check the pump tomorrow with my dad quick! Hope this sorts it lol!! Cheers Link to comment Share on other sites More sharing options...
dazzysri Posted April 16, 2009 Share Posted April 16, 2009 what about changing your fuel filter could be a blockage Link to comment Share on other sites More sharing options...
