southendboy Posted July 3, 2003 Share Posted July 3, 2003 My Mk 6 si overheats well quick, does anyone else get this?? Jus wanna see if its a commmon thing or if my car is Fuc ked? Link to comment Share on other sites More sharing options...
muzzy Posted July 3, 2003 Share Posted July 3, 2003 My Mk 6 si overheats well quick, does anyone else get this?? Jus wanna see if its a commmon thing or if my car is Fuc ked? My lightly modded 1.6 stays cool as a fox:) even when i thrash it. Check all the simple things like water hose's and cooling for leeks. check fan,radiator. Keep checking ur water levels on ur car and see if it goes down fast of normal? If its getting really hot becaful it can damage the engine then u will be fcuked. Link to comment Share on other sites More sharing options...
southendboy Posted July 3, 2003 Author Share Posted July 3, 2003 yeah i wouldnt be too impressed if that happened, water levels seem ok, i think the car is still under warrenty so mite be able to get them to sort it Link to comment Share on other sites More sharing options...
muzzy Posted July 3, 2003 Share Posted July 3, 2003 yeah i wouldnt be too impressed if that happened, water levels seem ok, i think the car is still under warrenty so mite be able to get them to sort it yeah deffently do that.Normely i just book it in cause mies under warrenty to and let them do all the hard work. i just wouldnt drive to fast untill its sorted. Which u know Link to comment Share on other sites More sharing options...
southendboy Posted July 3, 2003 Author Share Posted July 3, 2003 i think they will be glad to see the back of me, got em to sort loads of stuff so far, and ive made em go to Fords bout it all aswell, Jus got a new power steering switch put on it cos the revs were sticking. Dont spose you know of anyone selling rear spats?? Link to comment Share on other sites More sharing options...
muzzy Posted July 3, 2003 Share Posted July 3, 2003 i think they will be glad to see the back of me, got em to sort loads of stuff so far, and ive made em go to Fords bout it all aswell, Jus got a new power steering switch put on it cos the revs were sticking. Dont spose you know of anyone selling rear spats?? lol . best to get ur monie's worth out the warrenty. thats what its there for. no, ive allready got some welded on me car. got mine from esp Link to comment Share on other sites More sharing options...
McRic Posted July 3, 2003 Share Posted July 3, 2003 no, ive allready got some welded on me car. got mine from esp how did ye weld plastic Link to comment Share on other sites More sharing options...
muzzy Posted July 3, 2003 Share Posted July 3, 2003 no, ive allready got some welded on me car. got mine from esphow did ye weld plastic using abs cement. mek Link to comment Share on other sites More sharing options...
John Posted July 3, 2003 Share Posted July 3, 2003 how did ye weld plastic using a plastic welder? they are briliant bits of kit Link to comment Share on other sites More sharing options...
muzzy Posted July 3, 2003 Share Posted July 3, 2003 Yep we use polyprop. welders at work for our water tanks. Link to comment Share on other sites More sharing options...
Mk6 Si Ross Posted July 4, 2003 Share Posted July 4, 2003 can you hear ur radiator fan come in when it gets quite/very hot?? if not maybe its ur radiator fan switch if these modernish engines still have them!?!! Link to comment Share on other sites More sharing options...
John Posted July 4, 2003 Share Posted July 4, 2003 yeah they still have rad fan switches on "modern engines" could be worth checking out the thermostat, if it's sticking shut then that could be the cause. of course in the extreme case u've always got the possibilty of a beloved head gasket being blown Link to comment Share on other sites More sharing options...
southendboy Posted July 7, 2003 Author Share Posted July 7, 2003 Yeah the fan still comes on, dont like the sound of the head gasket gone, Link to comment Share on other sites More sharing options...
muzzy Posted July 7, 2003 Share Posted July 7, 2003 Yeah the fan still comes on, dont like the sound of the head gasket gone, most people dont lol Link to comment Share on other sites More sharing options...
BlairM Posted July 15, 2003 Share Posted July 15, 2003 could be worth checking out the thermostat, if it's sticking shut then that could be the cause. Just about to post a new thread, but spotted this one...my question is.. Where is the thermostat on a 1.4 EFi ?? Apparently, I've been told that it's knackered because the temp guage on the dash should point straight up at 12 o clock in the middle of where it says normal, whereas mine points to just below the n in normal Ta Link to comment Share on other sites More sharing options...
