Norcostreet Posted February 9, 2010 Share Posted February 9, 2010 My front sidelights and headlights are brighter on the passenger side and my electric mirrors keep making strange noises. It doesnt matter whether the igntion is on or off but the driver side lights are 50% dimmer than the passenger side. All the bulbs are the same and ive checked connections/fuses/relays, no problems there. Fuse box maybe? As for the mirrors, doomed. They dont work when i use the knob but they make little whirring noises on long journeys. Once again, ive checked wires/connections/fuses/relays. Nothing out of the ordinary. Is there a doctor in the house? Link to comment Share on other sites More sharing options...
dutchkev Posted February 9, 2010 Share Posted February 9, 2010 headlights - have you checked their aligned properly? reason i ask is because i had a focus with the same issuesm i though it was bulbs so i changed them, no difference, its only when it went for MOT the tester said the beam was pointind down to much as for the mirriros, sounds like the motor or the switch is faulty/buggered Link to comment Share on other sites More sharing options...
Norcostreet Posted February 11, 2010 Author Share Posted February 11, 2010 It went through the mot ok so i dont know about the alignment thing. Its the brightness difference thats bothering me. Ive tried a different switch for the mirrors and still no joy. Ill borrow some other mirrors off someone and try them to see if its my motors that are dead. Link to comment Share on other sites More sharing options...
Norcostreet Posted February 21, 2010 Author Share Posted February 21, 2010 i borrowed my friends mirrors for a day and got the same result, not working. Put them back in his, they work. Ive changed the switch again...not workingChecked all connections and wires...not workingYanked fusebox out and cleaned it...not workingReplaced all fuses and relays...not working AAAAAAAAARRRRRRRRRRGGGGGGGGGGGGGGHHHHHHHHHHH!!!! Help? Link to comment Share on other sites More sharing options...
