Yokomo Posted February 23, 2010 Share Posted February 23, 2010 Hello, i bought a escort 1.6 L reg non running, the battery had been disconnected for nearly 2 years, got a new battery tryed to start it no luck, checked spark and it only has a spark on 2 cylinders, so changed plugs, leads and coil pack and didnt make no difference only spark on 2 cylinders, any ideas? thanks. Link to comment Share on other sites More sharing options...
trickydicky Posted February 23, 2010 Share Posted February 23, 2010 Hello, i bought a escort 1.6 L reg non running, the battery had been disconnected for nearly 2 years, got a new battery tryed to start it no luck, checked spark and it only has a spark on 2 cylinders, so changed plugs, leads and coil pack and didnt make no difference only spark on 2 cylinders, any ideas? thanks. Welcome to the site Yokomo!You checked the injectors and fuel lines? Link to comment Share on other sites More sharing options...
Yokomo Posted February 23, 2010 Author Share Posted February 23, 2010 yes is getting fuel but its still not sparking at cylinders 1 and 4 Link to comment Share on other sites More sharing options...
Stu Posted February 23, 2010 Share Posted February 23, 2010 What year is it? Sounds like one of the feeds to the coilpack is broken, assuming your replacement coil isn't faulty too. Link to comment Share on other sites More sharing options...
Yokomo Posted February 23, 2010 Author Share Posted February 23, 2010 L reg so 94, yes the coil was taken off a running car Link to comment Share on other sites More sharing options...
Stu Posted February 23, 2010 Share Posted February 23, 2010 L reg so 94, yes the coil was taken off a running car If it uses an external EDIS module (and respective wiring) it might be worth checking this out. The module can be found on the offside inner wing. I posted a pin-out of the EDIS 4 module on here the other day so have a bit of a search if you need it. Link to comment Share on other sites More sharing options...
Yokomo Posted February 23, 2010 Author Share Posted February 23, 2010 ok will have a look at this then , i got it running once only on 2 cylinders, and rev counter was all jumpy, thanks for your quick reply Link to comment Share on other sites More sharing options...
Yokomo Posted February 23, 2010 Author Share Posted February 23, 2010 Update, just went to start it now no spark at all, and could not find edis module. any ideas? what else to try really need to get the car running Link to comment Share on other sites More sharing options...
Stu Posted February 23, 2010 Share Posted February 23, 2010 If it doesn't have an external EDIS module then really it could be many things.. faulty ECU.. wiring loom problem.. Link to comment Share on other sites More sharing options...
Yokomo Posted February 23, 2010 Author Share Posted February 23, 2010 hmm im guessing its to do with the wiring, because iv noticed alot of the wires have water on them or dripping off under the dash Link to comment Share on other sites More sharing options...
Stu Posted February 23, 2010 Share Posted February 23, 2010 hmm im guessing its to do with the wiring, because iv noticed alot of the wires have water on them or dripping off under the dash A common water leak on an Escort is where the main wiring loom goes through the main bulkhead behind the inner wheel arch. Water can run down into the ECU. You've probably got corrosion in there and potentially damaged the ECU. Link to comment Share on other sites More sharing options...
Yokomo Posted February 24, 2010 Author Share Posted February 24, 2010 anyone from kent willing to come down and have a look? really need this sorted asap will pay? Link to comment Share on other sites More sharing options...
