low_red_loud Posted August 27, 2010 Share Posted August 27, 2010 just changed the starter motor on a friends 2001 modeo face lift shape 2.0tdi took the battery lead off as necessary and when finished the job the airbag light stays on the ew don't work nor does the heater is there a easy way to reset the airbag light or has it got to be plugged into a computer to reset it? it doesn't state anything on my autodata please help!! Link to comment Share on other sites More sharing options...
etrebus Posted August 27, 2010 Share Posted August 27, 2010 its sounds like you have blown a fuse? Link to comment Share on other sites More sharing options...
kitted_escort Posted August 27, 2010 Share Posted August 27, 2010 the only thing i can think of is when you put the battery back on it blown a fuse Link to comment Share on other sites More sharing options...
low_red_loud Posted August 29, 2010 Author Share Posted August 29, 2010 fuses all ok relays ok too Link to comment Share on other sites More sharing options...
scottg17 Posted August 30, 2010 Share Posted August 30, 2010 (edited) old trick with all the fords with the airbag light coming on,, Unplug and replug in the pretensioners under both drivers and passangers seats Edited August 30, 2010 by scottg17 Link to comment Share on other sites More sharing options...
