ANT Posted August 20, 2003 Share Posted August 20, 2003 i am running 2 600w 12" pioneer subs off a 2 channel 800w amp.. what can be causing the subs to b out of phase with eachother?? sounds pretty crappy at the moment cheersant Link to comment Share on other sites More sharing options...
sime73 Posted August 20, 2003 Share Posted August 20, 2003 did u wire the subs in parallel ??should be the same then Link to comment Share on other sites More sharing options...
B19 JUB Posted August 21, 2003 Share Posted August 21, 2003 are they wired up exactly the same way?have u got a setting on your head unit to put subs out of phase? Link to comment Share on other sites More sharing options...
ANT Posted August 22, 2003 Author Share Posted August 22, 2003 i dunno if this is a dumb quest.. but is it possible that the subs are workin in stereo??? i think i have different ways of wiring 2 subs to my amp so i am gonna check it out the weekend.. Link to comment Share on other sites More sharing options...
djxl_da_beast Posted August 22, 2003 Share Posted August 22, 2003 To change the phase u switch the positive and negative over (on the back of the sub, not he amp ) his means it will be pushing instead of pulling if u no wot i mean - u should do this if the subs are facing each other. Link to comment Share on other sites More sharing options...
ANT Posted August 22, 2003 Author Share Posted August 22, 2003 To change the phase u switch the positive and negative over (on the back of the sub, not he amp ) his means it will be pushing instead of pulling if u no wot i mean - u should do this if the subs are facing each other. was gonna try this.. will have go tomoz! Link to comment Share on other sites More sharing options...
