jghs83 Posted May 13, 2011 Share Posted May 13, 2011 i know how to change a door but what is other peoples experiences with doing so? any problems? Link to comment Share on other sites More sharing options...
marshy Posted May 14, 2011 Share Posted May 14, 2011 i never really had any problems with the doors on my white one.. just little adjustments using the grub screws on the hinges...its better as a 2 person job tho (one person holding the door and the other making the adjustments..)..what problems are you having?? or are you just enquiring about any problems you might come across??if the doors you are getting are already off the car... make sure you check all the edges etc and the straightness.. Link to comment Share on other sites More sharing options...
escortmk5 Posted May 14, 2011 Share Posted May 14, 2011 total nightmare mate.. Link to comment Share on other sites More sharing options...
marshy Posted May 14, 2011 Share Posted May 14, 2011 Interested as to why you found it total nightmare mate.. ??? Knowing jay has some mechanical knowledge,I very much doubt this to be the case for him (TBF....it doesn't take that much to change a door!) Jay mate, if you get stuck, gis a bell ill fly over n give u a hand mate Link to comment Share on other sites More sharing options...
escortmk5 Posted May 14, 2011 Share Posted May 14, 2011 the 1st escort i had i changed the doors..perfect fit but the second escort i had i changed them but had to grind down the hinges and bend the hinges until the door fit perfect.. then welded the hinges wer i grinded it.. Link to comment Share on other sites More sharing options...
jghs83 Posted May 14, 2011 Author Share Posted May 14, 2011 Its just allignment that im fussy about. Ive found a set of 4 doors local in silver and was just gonna try before i buy. The actual swap will take at most 5 minutes per door. Its setting em up that be a pain. Link to comment Share on other sites More sharing options...
mattius Posted May 16, 2011 Share Posted May 16, 2011 i've taken does off in the past that seem to be welded on to the hinges, and the others that almost fall off. Only re-fitted 2 doors but never really had enlignment issues with them Link to comment Share on other sites More sharing options...
ALL4SHOW Posted July 22, 2011 Share Posted July 22, 2011 just reading this as im struggling to remove some doors to go on my van !!!! ive undone the grub screws,wiring & check strap & they still wont move !!!! tried lifting them off with a block of wood on a jack but it just lifts the car. is it just rusty pins holding them on ??? is there any hints or tips ???ive soaked them in wd40 but dont have access to oxy & think it will take for ever with a blow lamp Link to comment Share on other sites More sharing options...
jghs83 Posted July 22, 2011 Author Share Posted July 22, 2011 just reading this as im struggling to remove some doors to go on my van !!!! ive undone the grub screws,wiring & check strap & they still wont move !!!! tried lifting them off with a block of wood on a jack but it just lifts the car. is it just rusty pins holding them on ??? is there any hints or tips ???ive soaked them in wd40 but dont have access to oxy & think it will take for ever with a blow lamp should be a simple lift??? but it wont harm to put a bit of heat on to free them off. Link to comment Share on other sites More sharing options...
ALL4SHOW Posted July 22, 2011 Share Posted July 22, 2011 over the years ive worked out with my cars nothing is as ever simple as it should be !!!! HA HA . does the pin stay in the door part of the hinge or the car part ?? i just thought it would be simpler to swap the doors over with the electrics than swap over just the electrics Link to comment Share on other sites More sharing options...
jghs83 Posted July 22, 2011 Author Share Posted July 22, 2011 over the years ive worked out with my cars nothing is as ever simple as it should be !!!! HA HA . does the pin stay in the door part of the hinge or the car part ?? i just thought it would be simpler to swap the doors over with the electrics than swap over just the electrics you start with an easy 20 minute job that last 4 hours!!! yeah the pin will stay in the door hinge. well it should do at least Link to comment Share on other sites More sharing options...
lee grout Posted July 22, 2011 Share Posted July 22, 2011 just reading this as im struggling to remove some doors to go on my van !!!! ive undone the grub screws,wiring & check strap & they still wont move !!!! tried lifting them off with a block of wood on a jack but it just lifts the car. is it just rusty pins holding them on ??? is there any hints or tips ???ive soaked them in wd40 but dont have access to oxy & think it will take for ever with a blow lamp Mine lifted up when trying to lift it with a jack! Lift and wiggle side to side and it will ease out. You'll never lift it of easy unless your 100% virtical to the car. Wiggle bit by bit. Might look funny ( like your dancing with it!) but it'll work. Link to comment Share on other sites More sharing options...
ALL4SHOW Posted July 22, 2011 Share Posted July 22, 2011 just reading this as im struggling to remove some doors to go on my van !!!! ive undone the grub screws,wiring & check strap & they still wont move !!!! tried lifting them off with a block of wood on a jack but it just lifts the car. is it just rusty pins holding them on ??? is there any hints or tips ???ive soaked them in wd40 but dont have access to oxy & think it will take for ever with a blow lamp Mine lifted up when trying to lift it with a jack! Lift and wiggle side to side and it will ease out. You'll never lift it of easy unless your 100% virtical to the car. Wiggle bit by bit. Might look funny ( like your dancing with it!) but it'll work.yeah been trying that aswell but on the plus side my beerbelly & man boobs are cleaning the windows but yeah i will keep at it or if it comes to it i'll chop the hinges off the car as its scrap Link to comment Share on other sites More sharing options...
