KW-rscos Posted March 26, 2012 Share Posted March 26, 2012 Hi Guys, I have an Old Mondeo 2.0 Zetec ECU, code named EARS which is pre-PATS but for an AUTO, Can it be used to power a Manual 2.0 converted GTi (yes I know some of the pins need swapping to get I to plug directly into the loom). Any advice much appreciated!!! Link to comment Share on other sites More sharing options...
AdamXR3i Posted March 26, 2012 Share Posted March 26, 2012 I dont know what pins require swapping but i have the same ECU on my mk5b. Runs and drives absolutely fine. Link to comment Share on other sites More sharing options...
Stu Posted March 26, 2012 Share Posted March 26, 2012 Yes it can be used. Link to comment Share on other sites More sharing options...
KW-rscos Posted March 26, 2012 Author Share Posted March 26, 2012 I dont know what pins require swapping but i have the same ECU on my mk5b. Runs and drives absolutely fine. So just to be sure, your Mk5b runs a 2.0 Zetec on the EARS ECU, you don't have any issues with the map changing up or down the gears?Sorry to be so pedantic, just been told by someone you can't run it :s Cheers, Kieren Link to comment Share on other sites More sharing options...
Stu Posted March 26, 2012 Share Posted March 26, 2012 An ECU isn't going to change gears on a manual gearbox........ Yes, the auto cal is different, but nothing you'd notice. Link to comment Share on other sites More sharing options...
KW-rscos Posted March 26, 2012 Author Share Posted March 26, 2012 An ECU isn't going to change gears on a manual gearbox........ Yes, the auto cal is different, but nothing you'd notice. I know it doesnt change the gears in an auto, but i was told the map would not be right, but I am happy that you all have confirmed that it will, lol Thanks guys, much appreciated Link to comment Share on other sites More sharing options...
AdamXR3i Posted March 26, 2012 Share Posted March 26, 2012 I dont know what pins require swapping but i have the same ECU on my mk5b. Runs and drives absolutely fine. So just to be sure, your Mk5b runs a 2.0 Zetec on the EARS ECU, you don't have any issues with the map changing up or down the gears?Sorry to be so pedantic, just been told by someone you can't run it :s Cheers, Kieren Honestly mate it runs absolutely fine. Get could mpg aswell. 33mpg average. lol. Link to comment Share on other sites More sharing options...
the_big_man Posted March 30, 2012 Share Posted March 30, 2012 i take it you are running external EDIS as the in DEEP,DESK & DEWY are internal as far as i'm aware Link to comment Share on other sites More sharing options...
