tockwell Posted March 31, 2012 Share Posted March 31, 2012 Hello, Both of my DCOM carbs have started leaking fuel from the bottom of them. Does anybody have any experience of this? I've order a service kit and shall probably replace the gaskets. The carbs have been properly set up. I am quite annoyed as I have just finished replacing the rest of the system. I have no idea how long this has been happening though, but is quite lucky I noticed I suppose! Link to comment Share on other sites More sharing options...
Ahmotorsport Posted March 31, 2012 Share Posted March 31, 2012 Hello, Both of my DCOM carbs have started leaking fuel from the bottom of them. Does anybody have any experience of this? I've order a service kit and shall probably replace the gaskets. The carbs have been properly set up. I am quite annoyed as I have just finished replacing the rest of the system. I have no idea how long this has been happening though, but is quite lucky I noticed I suppose!Where they bolt to the manifold or actually underneath the carbs? Link to comment Share on other sites More sharing options...
tockwell Posted March 31, 2012 Author Share Posted March 31, 2012 Hello, Both of my DCOM carbs have started leaking fuel from the bottom of them. Does anybody have any experience of this? I've order a service kit and shall probably replace the gaskets. The carbs have been properly set up. I am quite annoyed as I have just finished replacing the rest of the system. I have no idea how long this has been happening though, but is quite lucky I noticed I suppose!Where they bolt to the manifold or actually underneath the carbs? The actual underneath of the carb. Appears to be leaking from the 'bottom gasket' (36) http://petrolpowered.com/include/pages/tec...rams/dcoe45.png (My carbs are DCOM rather than DCOE though) Link to comment Share on other sites More sharing options...
tockwell Posted March 31, 2012 Author Share Posted March 31, 2012 I've just taken a picture and it is hard to see from where it is leaking. It does have a regulator (3psi), (but not a return until quite recently), but I think the fuel pump has been run for too long for the engine running (or on idle maybe) http://ockwell.net/car-temp/carb/1.jpghttp://ockwell.net/car-temp/carb/2.jpghttp://ockwell.net/car-temp/carb/3.jpg Link to comment Share on other sites More sharing options...
