ekkie7 Posted July 5, 2012 Share Posted July 5, 2012 Found my relays tried swapping around as adviced no change although it is very moist and the relays have rusted and gone green not all of them but a good two or threeSounds likely the fault is in relay box if its all rusty and green. You really need to get a auto Electrician in or buy a meter and check where the power stops!. I cant stress enough how much can be learnt by following a few tails with a meter, otherwise you are just shooting in the dark.. No pun intended!Good luck and let us know the results SparkieTbh if theres damp on your fusebox,you got a leak somewhere,think there is a few posts on here that will give you advice about that as for the fusebox,i would just change it when you got your damp issue sorted. Link to comment Share on other sites More sharing options...
