Strikey Posted June 27, 2012 Share Posted June 27, 2012 I noticed my headlights where dull the other day i have changed bulbs fuses even the stalk and no changes. When i have my lights on this setting sidelightshttp://strikeys-pic.com/images/2012/06/27/N9Osm.jpgi get thishttp://strikeys-pic.com/images/2012/06/27/x4KQd.jpgwhen i have them on fullhttp://strikeys-pic.com/images/2012/06/27/ajQGi.jpgi get thishttp://strikeys-pic.com/images/2012/06/27/KiETo.jpgas you may have noticed that the first setting sidelights is brighter than my full lights My question to you is could it be wiring or is it a common problem also instead of paying for an auto electrician is there no electrical diagram or some explained loom for the headlights so i can check the wiring? All help would be really appreciated Link to comment Share on other sites More sharing options...
hicksy Posted June 27, 2012 Share Posted June 27, 2012 I wouldnt mind betting its the stalks themselves mate, i had this on my cabby a few years ago. The lights would play silly buggers all the time and when i put some replacement stalks on, the problem went away Link to comment Share on other sites More sharing options...
Strikey Posted June 27, 2012 Author Share Posted June 27, 2012 I wouldnt mind betting its the stalks themselves mate, i had this on my cabby a few years ago. The lights would play silly buggers all the time and when i put some replacement stalks on, the problem went away already replaces my current stalk with another one Link to comment Share on other sites More sharing options...
hicksy Posted June 27, 2012 Share Posted June 27, 2012 I wouldnt mind betting its the stalks themselves mate, i had this on my cabby a few years ago. The lights would play silly buggers all the time and when i put some replacement stalks on, the problem went away already replaces my current stalk with another one Was it a tested set? I got a set from the scrappy once and they didnt work either, i then fitted a set that was tested and they worked. 99/100 times its the stalks that give the problems Link to comment Share on other sites More sharing options...
Strikey Posted June 27, 2012 Author Share Posted June 27, 2012 I wouldnt mind betting its the stalks themselves mate, i had this on my cabby a few years ago. The lights would play silly buggers all the time and when i put some replacement stalks on, the problem went away already replaces my current stalk with another one Was it a tested set? I got a set from the scrappy once and they didnt work either, i then fitted a set that was tested and they worked. 99/100 times its the stalks that give the problems Should i try the current stalk in the car wher i got it from and see if it works? Link to comment Share on other sites More sharing options...
hicksy Posted June 27, 2012 Share Posted June 27, 2012 I wouldnt mind betting its the stalks themselves mate, i had this on my cabby a few years ago. The lights would play silly buggers all the time and when i put some replacement stalks on, the problem went away already replaces my current stalk with another one Was it a tested set? I got a set from the scrappy once and they didnt work either, i then fitted a set that was tested and they worked. 99/100 times its the stalks that give the problems Should i try the current stalk in the car wher i got it from and see if it works? If thats possible? Its worth a try Link to comment Share on other sites More sharing options...
stoo2000 Posted June 27, 2012 Share Posted June 27, 2012 Start your engine, then look... Link to comment Share on other sites More sharing options...
redmex Posted June 27, 2012 Share Posted June 27, 2012 I noticed my headlights where dull the other day i have changed bulbs fuses even the stalk and no changes. When i have my lights on this setting sidelightshttp://strikeys-pic.com/images/2012/06/27/N9Osm.jpgi get thishttp://strikeys-pic.com/images/2012/06/27/x4KQd.jpgwhen i have them on fullhttp://strikeys-pic.com/images/2012/06/27/ajQGi.jpgi get thishttp://strikeys-pic.com/images/2012/06/27/KiETo.jpgas you may have noticed that the first setting sidelights is brighter than my full lights My question to you is could it be wiring or is it a common problem also instead of paying for an auto electrician is there no electrical diagram or some explained loom for the headlights so i can check the wiring? All help would be really appreciated Check Dim Dip relay I wd say.. Link to comment Share on other sites More sharing options...
tomsy Posted June 27, 2012 Share Posted June 27, 2012 I've had 2 diferent problems with lights on 2 escorts i've owned both times changed the stalks sorted Link to comment Share on other sites More sharing options...
SteveB Posted June 28, 2012 Share Posted June 28, 2012 What do you get on high beam? Same as dipped? Link to comment Share on other sites More sharing options...
Strikey Posted June 28, 2012 Author Share Posted June 28, 2012 Start your engine, then look... It was when the engine was started when i noticed it when i was driving home I noticed my headlights where dull the other day i have changed bulbs fuses even the stalk and no changes. When i have my lights on this setting sidelightshttp://strikeys-pic.com/images/2012/06/27/N9Osm.jpgi get thishttp://strikeys-pic.com/images/2012/06/27/x4KQd.jpgwhen i have them on fullhttp://strikeys-pic.com/images/2012/06/27/ajQGi.jpgi get thishttp://strikeys-pic.com/images/2012/06/27/KiETo.jpgas you may have noticed that the first setting sidelights is brighter than my full lights My question to you is could it be wiring or is it a common problem also instead of paying for an auto electrician is there no electrical diagram or some explained loom for the headlights so i can check the wiring? All help would be really appreciated Check Dim Dip relay I wd say.. Where is that located and which one is it What do you get on high beam? Same as dipped? The high beam works fine no problem same as sidelights just no my main lights :/ Link to comment Share on other sites More sharing options...
redmex Posted June 28, 2012 Share Posted June 28, 2012 (edited) Right... Hoping this will help ,Obviously its hard to give a solid answer without getting a meter on your car but!!! .. My car headlights only work when ignition is on.. thats "Dip and main beam" So i would rule out your dim dip unit initially.. I have just sidelights when ignition is off.. Thinking logical it sounds poss your dipped headlight relay is naff or you have lost its feed.. Swap the dip relay for main beam and see what happens..? If no luck, buy a cheap meter or test light and follow the power using a haynes diagram until you find the fault. Nothing is strait forward in electrical faults.. Trust me im an electrician Sparkie Edited June 28, 2012 by redmex Link to comment Share on other sites More sharing options...
Strikey Posted June 30, 2012 Author Share Posted June 30, 2012 I have got my third stalk and all seems the same where are my dipped headlight relay and main beam relays located? Link to comment Share on other sites More sharing options...
Strikey Posted June 30, 2012 Author Share Posted June 30, 2012 Found my relays tried swapping around as adviced no change although it is very moist and the relays have rusted and gone green not all of them but a good two or three Link to comment Share on other sites More sharing options...
redmex Posted July 1, 2012 Share Posted July 1, 2012 Found my relays tried swapping around as adviced no change although it is very moist and the relays have rusted and gone green not all of them but a good two or threeSounds likely the fault is in relay box if its all rusty and green. You really need to get a auto Electrician in or buy a meter and check where the power stops!. I cant stress enough how much can be learnt by following a few tails with a meter, otherwise you are just shooting in the dark.. No pun intended!Good luck and let us know the results Sparkie Link to comment Share on other sites More sharing options...
