danj8608 Posted October 21, 2012 Share Posted October 21, 2012 Right I have bought a 130bhp zetec engine, if I had a lesser spec zetec equipped car is it just a case swapping the engine over fit the ecu and transponder and job done. The reason I ask is some tit has cut the engine loom for the copper wire so need the to know if a lesser spec zetec loom can be used. Link to comment Share on other sites More sharing options...
supersport Posted October 21, 2012 Share Posted October 21, 2012 alloy or plastic inlet? the looms can be swapped over, but a couple of plugs need to be changed. Link to comment Share on other sites More sharing options...
danj8608 Posted October 21, 2012 Author Share Posted October 21, 2012 Alloy ho inlet Link to comment Share on other sites More sharing options...
supersport Posted October 21, 2012 Share Posted October 21, 2012 you can use the loom you already have. i have a MK5b loom modded to suit in my MK5 with a MK6 plastic inlet engine. Link to comment Share on other sites More sharing options...
danj8608 Posted October 21, 2012 Author Share Posted October 21, 2012 My car is a 1.4 cvh mate hence me asking about a less spec zetec loom as ill be doing a full loom swap also Link to comment Share on other sites More sharing options...
supersport Posted October 21, 2012 Share Posted October 21, 2012 should just be a straight swap, but if you are removing the loom yourself cut it past the plug by the battery just it case. Link to comment Share on other sites More sharing options...
